there are 4 studs/nuts that hold each seat in place
the nuts are covered with plastic covers
there is a push-pin deal that holds the covers on
pull out the center of the push-pin, remove the plastic cover, and remove the 4 nuts
the driver side harness has a snap connector, pry the retaining tab out of the way a little bit then pull apart
cover your door sill so you don't gouge the paint
:iagree: Also, check out the instructions section On Vette Essentials Website for detailed photos on the seat removal process! i just took mine out last week, and it went fairly easy once you figure out what you are doing! Good Luck....
Thanks guys for the info. I took the seats out, cleaned and polished them.
Did the carpet and all the inside while the seats were out.
Everything worked out okay especially with the roof out! :seeya
