Support Cam
Old May 2, 2003 | 01:57 PM
2KVetteMan's Avatar
2KVetteMan
Default Support Cam
HEy guys I need some info. I bought VStella cam off him a Lunati 227/227 L114. I know I need to get push rods and going to buy pulleys as well.
Questions:
1) What push rods do I buy?
2) Anyone selling a ASP pulley they don't want anymore?
3) Do you think I will need tuning or I can drive it like that without a problem for the time being?
4) Do you think I should buy new valve spring a lifters??
Thanks and all advice is taken into consideration.
:cheers:
Old May 2, 2003 | 02:42 PM
jmX's Avatar
jmX
Default Re: Support Cam (2KVetteMan)
1) reuse stock or go with 7.400 hardened.
2) dunno
3) in an m6 you can drive it as is for a while if you need. if you port your throttle body it'll idle a bit better
4) new springs are a must, new lifters I wouldnt worry about since you're just changing the cam. You'd have to take the heads off to change them anyway.
Jon
http://www.ls1howto.com
