O2 sensor question
Old May 5, 2003 | 06:56 PM
ZX1100's Avatar
ZX1100
Default O2 sensor question
I need to have some longer O2 sensor wires to be able to connect my sensors after a header install. Is there an easy way to lengthen the wires or some adaptor to lengthen them?
Old May 5, 2003 | 07:14 PM
z28lt1's Avatar
z28lt1
Default Re: O2 sensor question (ZX1100)
Yes, there are 02 sensor extenders available.
You can get them here: http://www.thunderracing.com/index.cfm?fuseaction=subcategory&subcate goryid=1046 (at the bottom)
[Modified by z28lt1, 7:15 PM 5/5/2003]
Old May 5, 2003 | 07:21 PM
Wt99C5's Avatar
Wt99C5
what kind of headers ?
Old May 5, 2003 | 07:53 PM
ZX1100's Avatar
ZX1100
Default Re: O2 sensor question (Wt99C5)
Thanks for the link. Actually it's for my Viper but posted here also for any info in maybe modifying them easily myself.
Old May 6, 2003 | 04:15 PM
z28lt1's Avatar
z28lt1
If you are handy with wiring and the soldering iron, I'm sure you can extend them yourself. I would extend them from the initial wiring, not between the sensor and connector. Also, don't know how the Viper is, but many cars have the wiring tied or clipped up in several places. You may be able to remove those to find enough extra length.
To O2 sensor question
