LOWERING>>>>>>>>>>
Old May 6, 2003 | 07:35 AM
BiscuitVette's Avatar
BiscuitVette
Default LOWERING>>>>>>>>>>
Does anyone know which size bolt and nut is needed to avoid spending 20 bucks on something that costs about 2 bucks in Home Depot
Old May 6, 2003 | 09:08 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: LOWERING>>>>>>>>>> (BiscuitVette)
The stock size is 1/2" so that is what I would recommend. It might be kind of hard to re-install the bushings on the 9/16" bolt. I would definitely get fine threaded grade-8 bolts with nylon locknuts. You can get them from McMaster-Carr or any industrial hardware dealer. I think ACE carries them too. If you haven't already lowered your car with the stock bolts, you can drop it 1-2" with the 6.5" bolts. This gives you plenty of adjustment range. Stock bolts will give you about an inch of drop.
_______ http://forums.corvetteforum.com/zerothread?id=550378
Old May 6, 2003 | 02:56 PM
BiscuitVette
Grumpy,
Thanks, do I need to do anything else in the front. i am not to big on cutting the bushings?
To LOWERING>>>>>>>>>>
