MTI 427 startup problems
Old May 6, 2003 | 02:24 PM
Guest
Guest
Posts: n/a
Default MTI 427 startup problems
Hi everyone, we have a funny problem with my friends new MTI 427
C5R engine.
It starts ok, idles kind of rough, have not done idle relearn procedyre yet.
After a while, my friend went trough different gears (idle standing still) and we shut her down.
Then we cant get her to start up again ???
It tries to start, but shuts down again.
With Ease scanner i looked at all DTC and cleared them, there was two B errors, cant remember #, but it was regarding battery.
a few U errors, and one Pxxxx regarding TCM something.
Not anything that should indicate engine failure......
After a little cool down period, engine started up nice again ? wtf.....
Same thing happen over again, go trough gears, shut down and would not start again.
pleeese help out if anyone know where to start..
Old May 6, 2003 | 02:45 PM
J-Rod's Avatar
J-Rod
Default Re: MTI 427 startup problems (c5norway)
My buddy has a similar issue. His car starts fine, if you shut it down and try to do a warm restart the car dies unless you feed it throttle. I think he need a bit more tuning. But I will ask around a bit more...
Old May 6, 2003 | 04:03 PM
Guest
Guest
Posts: n/a
Default Re: MTI 427 startup problems (J-Rod)
My friends car does not start regardsless how much trottle
we give her.
Old May 6, 2003 | 04:52 PM
gojo's Avatar
gojo
I don't know if LSI edit and the PCM in a 98' has the iac park and running airflow tables in the idle and limiters tab. If it does, raise the values in iac park by .05 at a time, at temps 80c and up. If you don't have the tables try multiplying the Main VE tables by 60% in 400 to 1200 columns.
Old May 6, 2003 | 05:15 PM
Guest
Guest
Posts: n/a
Default Re: MTI 427 startup problems (jfpilla)
Thanks, we will try that tomorrow (late night here now)
Old May 6, 2003 | 06:16 PM
rfgoss1's Avatar
rfgoss1
C5R engine.
Just wondering what MTI had to say? I assume that you have called them. They will be the best source for a solution on their engine. Just a thought. I know that when I have a problem, Lou is the guy I call and he would get pissed if I called someone else on his engine.
Best of luck
Randy Goss
Old May 6, 2003 | 06:18 PM
rfgoss1's Avatar
rfgoss1
C5R engine.
did you put a new computer or a new program in the computer? It sounds like the security defeat is kicking in. If you haven't tried it yet, do a full relearn first.
Best of luck
Randy Goss
Old May 7, 2003 | 02:32 AM
Guest
Guest
Posts: n/a
Default Re: MTI 427 startup problems (rfgoss1)
We will try Lou today, thanks.
But i thought i would try the fantastic knowlegde of this forum, to see if there was anyone with the excact same experience :-)
A full relearn will be done
Old May 7, 2003 | 06:19 AM
99 WS-7's Avatar
99 WS-7
Check the Mass Airflow Sensor. I had the same problem opon start-up. Wiggle the wires a little bit. I hope that helps.
Old May 7, 2003 | 08:23 AM
Waterfreak's Avatar
Waterfreak
Default Re: MTI 427 startup problems (99 WS-7)
We have been tuning for that specific problem for the last few days on my MTI X1 cam car. It is worst when the AC is on when starting it hot. Basically, Jim has been increasing the initial air flow for additional revolutions of the cam and it is working it out. We almost have it.
Old May 7, 2003 | 10:35 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: MTI 427 startup problems (Waterfreak)
Do the security relearn procedure and then do the crank position sensor relearn procedure.
Good luck. :cheers:
Old May 7, 2003 | 11:05 AM
Austrian Vette's Avatar
Austrian Vette
Rune, what year PCM does he have??
If it is 99 or 2000 you can try my idle runing.
It worked perfect for me.
My engine didn´t start without it.
I would share the with you.
Robert (RWJ383) who did my idle tune got it near 100% right on the first try!!!
Michael
Old May 7, 2003 | 01:55 PM
gojo's Avatar
gojo
Default Re: MTI 427 startup problems (Austrian Vette)
:iagree:
This is the easiest, cheapest and very safe place to start. As long as you have a copy of your MTI PCM file you can always restore it. More and more people are finding out about using the idle and limiters section to correct startup, idle, surging, hunting racing etc. This tuning will not effect the WOT performance of your car.
Old May 7, 2003 | 02:33 PM
rwj383's Avatar
rwj383
Michael
send me your latest Edit tune. Yes, my service is (still) free!! I just love doing it. I need to know:
1. engine specs
2. trans type + stall converter size
3. Fuel octane used daily
4. Naked pictures of women from your country (ok, not a requirement, but, it will help!!!:o)
5. any scan you can provide in .txt format.
I will do the rest.
We'll fix you up right nice!! If you have an A4 trans, Michael Drs can share his tune with you. Caveat- top secret stuff in it!! ok, maybe not...:o)
All joking aside...i can help you if you send me the above info (naked pics are definitely bonus points!!)
Robert Judd
NiTech Motorsports
[Modified by rwj383, 11:45 AM 5/7/2003]
Old May 7, 2003 | 03:07 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
The problem is IAC park and idle airflow.. common issues with larger cams in these strokers.. 10 minutes with LS1Edit and you're all fixed...
Old May 7, 2003 | 03:14 PM
gojo's Avatar
gojo
Default Re: MTI 427 startup problems (rwj383)
I've mailed my file to you. Add it to your experience. My mods are listed. jfpilla :thumbs:
Copy me on the photos. :lol:
[Modified by jfpilla, 3:21 PM 5/7/2003]
Old May 7, 2003 | 04:58 PM
Guest
Guest
Posts: n/a
Hi Michael, PCM is 1997, and tonight i think we solved it.
First we drilled a small hole in trottle blade, next we found a little vacuum leak, actually the Vacuum to Level IV trans was disconnected back at the trans :-o
Did the security learn procedyre, idle learn and now it seems ok.
Thanks everyone for input and assistanse.
To MTI 427 startup problems
