which are the best?
Old May 6, 2003 | 06:55 PM
firemanrandy's Avatar
firemanrandy
Default which are the best?
Which spark plugs are the best to use on the C5's?
Old May 6, 2003 | 10:11 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: which are the best? (amandasguy)
NGK TR55-stock and bolt-ons
NGK TR6- Higher CR heads and cam,Turbos and S/C.
This is what I found in a recent search of several sites. Good Luck. :steering: :cheers:
Old May 7, 2003 | 12:36 AM
Chris@SD's Avatar
Chris@SD
Default Re: which are the best? (binksZ06)
Perfect advice.
Give me a ring if you need any more advice.
Thanks,
To which are the best?
