Wiper Problem
Old May 7, 2003 | 09:48 AM
SZZZL's Avatar
SZZZL
Default Wiper Problem
Yesterday it was raining and wipers worked fine all the way to work. When
I came back out after woork and start car the wipers won't turn off.
I can adjust the speeds however when I switch to off they stay on intermittently. This is on a 1999 C5 Coupe
Any Ideas? and how difficult of a fix is it?
Old May 7, 2003 | 10:49 AM
Vette Foot's Avatar
Vette Foot
3rd Gear
Default Re: Wiper Problem (SZZZL)
Hey there, I have a 99 coupe with wiper problems also.
See question from Vette Foot. I'm hoping for some help as well.
If I get any help that will apply to you, I will certainly pass that info.
on to you. I would appreciate it if you could do the same.
Good Luck !
Old May 8, 2003 | 10:28 AM
EWill3rd's Avatar
EWill3rd
Default Re: Wiper Problem (Vette Foot)
Fellers,
The Pulse board, or the controller, is integrated into the wiper motor.
The switch on the column is merely a ground with a bunch of resistors in it.
There is an IC timer inside the module and the varied resistance through the ground (switch) makes the timer go longer or shorter between pulses based on your setting. There are different positions for low and high wipe.
Most likely your problem is in the wiper motor itself.
Moisture has probably gotten in there and ruined something.
I have not seen that problem myself, proper diagnosis should be done but if you don't want to deal with it, I would say replacing the wiper motor and pulse board (usually serviced as one unit) should take care of your problem.
Probably not a cheap proposition.
Again, I haven't done one yet on a C5.
Switches fail even more rarely.
EWill
To Wiper Problem
