OK, this time I want an answer
Old May 7, 2003 | 11:47 AM
bierbelly's Avatar
bierbelly
Default OK, this time I want an answer
I've posted this question a couple of times in other's threads, but never gotten an answer.
GM sells a transmission oil/fluid called "Synchromesh", which seems to be a hot commodity with Mustang owners. However, to my knowledge, it isn't the factory fill in a Vette. Is GM Synchromesh OK to use in our trannies? Are there any issues with incompatibility with seals and the like? If it's not OK for Vettes, what the heck is it used for?
Thanks in advance for your consideration and comments. :confused:
Old May 7, 2003 | 12:06 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: OK, this time I want an answer (bierbelly)
I've heard Lablatts Blue works well in a C5 :seeya
Old May 7, 2003 | 02:53 PM
bierbelly's Avatar
bierbelly
ttt
Old May 7, 2003 | 03:08 PM
TLewis4095's Avatar
TLewis4095
??? Beats me..... :confused:
Old May 7, 2003 | 03:24 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: OK, this time I want an answer (Mr Mojo)
I've read several other posts that guys have used it & loved it. Said it made the tranny shift like butter. I think I remember reading that the stuff is a semi-synthetic. Should be finr to use. I think they said it will take 4 qts. If you're gonna buy it at the dealer, they should be able to answer your questions. SCOTT
Old May 7, 2003 | 03:39 PM
pmarone's Avatar
pmarone
Can't answer your question, but I can tell you there is information in the archives you can search. I stumbled across syncrhomesh topics when doing a different search yesterday.
Pete
Old May 16, 2003 | 09:08 PM
brrymnvette's Avatar
brrymnvette
Hell yeah, use it! It is good stuff.
Old May 16, 2003 | 09:16 PM
Admiral Fairway's Avatar
Admiral Fairway
It seems odd that there is a sticker on the trans and the manual also calls for Dexron III automatic transmission fluid. Bierbelly if you try the Syncromesh keep us informed on weather you feel and difference or not.
Old May 16, 2003 | 10:36 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: OK, this time I want an answer (cnl3rd)
:withstupid: As long as it meets this standard, you shouldnt' have any problems.....
To OK, this time I want an answer
