Lead proof Denso 02 sensor is working...
Old May 7, 2003 | 12:54 PM
J-Rod's Avatar
J-Rod
Default Lead proof Denso 02 sensor is working...
Many folks have been running 110 and 116 octane on these in the fast GN's and they just keep going with no fouling. On a GM o2 they'd get one run before it was toast.
http://www.turbobuick.com/forums/sho...threadid=65765
Old May 7, 2003 | 06:24 PM
Face's Avatar
Face
Default Re: Lead proof Denso 02 sensor is working... (J-Rod)
:cheers:
Old May 7, 2003 | 06:31 PM
Phil97SVT's Avatar
Phil97SVT
Where can the Denso sensors be purchased?
Phillip
Old May 7, 2003 | 08:19 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Lead proof Denso 02 sensor is working... (Phil97SVT)
Phillip
And how much???? :cheers:
Old May 8, 2003 | 02:54 AM
z0sense's Avatar
z0sense
I was reading the post on that forum and they are not heated and therefore not a direct replacement.
Unless of coarse they make one heated. The part number they had listed was:
Denso no. for the O2 is: 234-1001 $26.00
However at $26 you know that could not be our sensor:)
Old May 8, 2003 | 10:32 AM
Mike TexaSS's Avatar
Mike TexaSS
Default Re: Lead proof Denso 02 sensor is working... (z0sense)
My Impala SS's O2 sensores (AC DELCO) wont last one trip to the track with any kind of Leaded high octane fuel 108 112 116 only thing that wont kill the sensors is good ole 104 Unleaded.
Good info Jrod!
Old May 8, 2003 | 12:01 PM
J-Rod's Avatar
J-Rod
They have heated 02s...
For instance.
Denso P/N 234-4018
equivalent to AC DELCO P/N AFS 109
Cost: $26.00
You can get them anywhere. The big issue is going to your local parts store like AutoZone. Give them the PN#, or have them x-reference it to Denso. If they try to cross it to Bosch, tell them no, put in the part number. Once they do they will show up, and they can order it.
To look for PN#'s try:
SPARKPLUGS.COM
DENSOAFTERMARKET.COM
Old May 8, 2003 | 12:05 PM
J-Rod's Avatar
J-Rod
From Denso's site:
Sub Model Engine Part # Position (L/R) Location (F/R) DENSO OE Style # DENSO Universal #
-- V8/5.7 25312184 -- Front 234-4012 234-4000
-- V8/5.7 25312202 -- Rear 234-4617 234-4000
Z06 V8/5.7 25312184 -- Front 234-4012 234-4000
Z06 V8/5.7 25312202 -- Rear 234-4617 234-4000
Old May 8, 2003 | 02:19 PM
HurricaneZ's Avatar
HurricaneZ
So these better O2 sensor are cheaper than any replacement O2 sensor :confused: I had to buy o2 sensor on 2 different occations and never found anything cheaper than $80 at the autoparts stores.
Old May 8, 2003 | 02:53 PM
J-Rod's Avatar
J-Rod
Default Re: Lead proof Denso 02 sensor is working... (HurricaneZ)
The $26.00 was for the unheated 02's, for a set of heated 02's you are probably looking at $170 shipped.
To Lead proof Denso 02 sensor is working...
