Should I re-install the Steve Cole programming???
Old May 10, 2003 | 11:33 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Should I re-install the Steve Cole programming???
Just got the car from the dealer after they installed a new PCM. Trouble is I have the 3.42's and it was flashed back to 2.73 gears. Will it hurt to drive the car with the factory programming untill I decide if I want to go with LS1 Edit?????
Old May 10, 2003 | 12:37 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Should I re-install the Steve Cole programming??? (Mag Red Monster)
The early PPLII were not locked
Maybe someone knows when the cutoff date is ?
Old May 10, 2003 | 12:58 PM
2001 Red Coupe Bandit's Avatar
Default Re: Should I re-install the Steve Cole programming??? (SHOWTIME!)
It won't hurt it, but it might not drive perfectly. I think your mileage on the car will be off, if I am correct, you might be putting more miles on your odometer than you actually drive. I have a PL right now and just added 3.42's to replace my 3.15's which are 8.5 % differentcve so for every 100 miles I drive I put on 108.5 miles. In your case 2.73 to 3.42 is 20% so you will add even more. I am not 100% sure on this, but I think that is correct.
:D
Old May 10, 2003 | 01:40 PM
Mag Red Monster
Elite Member
That would be great to know......hoping someone will chime in with some aditional Info. Sure would be nice not to have to flash this back to factory before messing with the LS edit
Old May 10, 2003 | 02:09 PM
YO-EL's Avatar
YO-EL
Install it... :yesnod: So your car can drive like before.
If you get LS-1 edit, just get it flashed back to stock before the editing.
Old May 11, 2003 | 07:58 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Should I re-install the Steve Cole programming??? (indypace78)
but keep your kid away :lol: :lol:
Old May 11, 2003 | 08:08 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Bob....we'll know tomorrow morning when Mike Norris starts the tuning on my ride after the header install :)
I'm calling Mike at 10:30am....stay tuned :D
Old May 11, 2003 | 08:11 PM
Mag Red Monster
Elite Member
Default Re: Should I re-install the Steve Cole programming??? (Mean Green 2000)
I'm keeping my fingers crossed for you Mark. Hope your luck is better than mine. Here's what happens if you try and re-install the TTS programming................. I am totally screwed!
[Modified by Mag Red Monster, 8:12 PM 5/11/2003]
Old May 11, 2003 | 08:21 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
ahhh HOLY HELL Bob :(.........that sux :smash:
I've had the PL for almost 2 years and actually almost forgot about the "lock out" issues.....may not be able to pick the car up tomorrow, but we'll know early am what the scoop is :)
If need be, I have it reflashed then start fresh with Mike's tuning :)
To Should I re-install the Steve Cole programming???
