Alarms going off, 1999 Coupe
Old May 11, 2003 | 10:18 AM
daffyky's Avatar
daffyky
Default Alarms going off, 1999 Coupe
Recently, all the alarms have been going off, all guages go to zero, except alternator. Messages on message board run continuously. Took to dealer, said it was a body control module. Worked for a week, now doing it again about every 15-20 seconds. Also no power at all to passenger door. If I turn the vette off, and restart, alarms reset, but come back on. Taking vette back to dealer 5/12.03. Would like to have some working knowledge to be armed with. Thanks, Ken :banghead:
Old May 11, 2003 | 10:26 AM
Stilcrazee's Avatar
Stilcrazee
Default Re: Alarms going off, 1999 Coupe (daffyky)
I don't know what may be causing the problem, maybe a bad or coroded cable to the pcm?
I would make sure that the dealer you are using does service a volume of Vettes or you may be in for a long repair. A week seems to be too long to find the first, no maybe wrong problem...
Good Luck!
Old May 11, 2003 | 10:56 AM
tabbruzz's Avatar
tabbruzz
It's a 99 so take a look under the battery, if it's original it may be leaking acid. This was somewhat common and causes all kinds of issues because it burns through the wiring harness.
Tony
Old May 11, 2003 | 11:05 AM
Joe C5's Avatar
Joe C5
Default Re: Alarms going off, 1999 Coupe (tabbruzz)
Also have them check for a clogged A/C drain. Water leaking on the computer is a bad thing (been there done that). You can check yourself - water on passenger footwell carpet...
Old May 11, 2003 | 12:57 PM
daffyky's Avatar
daffyky
Tony,
Thanks for the reply. Battery was replaced when 99 was at dealers two weeks ago. :banghead:
Old May 11, 2003 | 01:00 PM
daffyky's Avatar
daffyky
Default Re: Alarms going off, 1999 Coupe (Joe C5)
No wetness detected. Was in fuse box checking fuses under floorboard. Thanks for the help though. Thought maybe this was a commonality.
Ken :banghead:
To Alarms going off, 1999 Coupe
