Dash cutting for hud
Old May 11, 2003 | 04:36 PM
Racer1x's Avatar
Racer1x
Default Dash cutting for hud
I'm installing hud into my 98 as I speak and was wondering if anyone had pics of the hole im supposed to cut in the dash?
I see the outline but dont know if I cut all the way to the end of the dash or not.
Any tips would be highly appreciated as I want to get this done.
Thanx in advance
Old May 11, 2003 | 11:07 PM
01c5z06's Avatar
01c5z06
Default Re: Dash cutting for hud (Racer1x)
Cut to the inside of the indentions in the pad. Then put the trim piece in and take a dremel tool and shape, little by little till you cut the pad to fit barely inside the lip on the trim piece. Be careful that you don't cut too much without fitting and then trimming it up to fit. When finished you will have a U-shaped hole to fit the trim piece into. Yes you cut all the way to the end and take out the piece of dash pad
Take your time!
Hope this helps.
[Modified by 01c5z06, 10:32 PM 5/11/2003]
Old May 11, 2003 | 11:15 PM
1SLANDON's Avatar
1SLANDON
No real closeups but might help. Good Luck. https://www.corvetteforum.com/techti...=144&TopicID=1
Old May 12, 2003 | 01:13 AM
Racer1x's Avatar
Racer1x
Default Re: Dash cutting for hud (C5Coup)
Thanks guys for the input, I just took my time made a few cuts with the dremel and it came out good. Cant tell its not factory from the top. :cheers:
Old May 12, 2003 | 08:38 PM
jim2527's Avatar
jim2527
How much are you guys paying for the parts to convert to HUD?
Old May 12, 2003 | 10:08 PM
George Cooper's Avatar
George Cooper
Default Re: Dash cutting for hud (jim2527)
I and probably many others would love to see a how-to for getting that dash pad off and back on - it would just need to pick up where some of the really good white face gauges how-tos leave off. Please......
Old May 13, 2003 | 03:48 AM
C5 Frederik's Avatar
C5 Frederik
I paid $900.00 for cluster, projector and bezel.
Frederik
Old May 15, 2003 | 01:43 PM
Racer1x's Avatar
Racer1x
I paid 650 shipped for all the parts to complete te job.If you have a 99 or newer you only need the projector and bezel.
Old May 15, 2003 | 01:59 PM
Crispyc21's Avatar
Crispyc21
$650 is not a bad deal. If you got it from a vendor of some sort send me the address. I have a 99 and thought I needed a new gauge cluster as well. I know I don't have the buttons on the left of my dash for the HUD controls. Does that mean I do need a new dash? I was thinking of doing the HUD the right way like you are or doing it using the cheap $250 HUD setup offered for the LT1 crowd.
Old May 16, 2003 | 09:49 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Dash cutting for hud (Crispyc21)
you may or may not have a HUD capeable cluster, you'll have to remove your cluster and see if it has a connector on the top for the HUD projector.
if yours has this connector, all you need is the HUD projector, HUD switch and harness, and HUD bezel.
BTW, I paid $300.00 at a swap meet for a cluster (with HUD switch) and HUD projector! the bezel cost $16.00 brand new from my local chevy dealer. :cheers: :party:
[Modified by RPOZ4Z, 9:49 AM 5/16/2003]
Old May 16, 2003 | 10:13 AM
kosbe's Avatar
kosbe
I read earlier on another thread that HUD cars have different windshields. The HUD projects on to the windshield. How or does that effect the HUD. :seeya
[Modified by kosbe, 3:14 PM 5/16/2003]
Old May 16, 2003 | 10:36 AM
Resqjoc's Avatar
Resqjoc
Default Re: Dash cutting for hud (kosbe)
I can tell you from personnel experience, I needed the cluster for my 99. I was shocked to find out, I did not have a HUD compatible cluster. I recommend anyone with a 99 to check first to see if you have the HUD cluster. I learned the hard way.
Old May 16, 2003 | 12:09 PM
BigBlue's Avatar
BigBlue
That's true. When my dad got a crack in his windshield, every place we called, including Chevy, said that it needed a special windshield. Cost, $1000+. One place wanted almost $2000.
Old May 16, 2003 | 11:43 PM
RPOZ4Z's Avatar
RPOZ4Z
Default Re: Dash cutting for hud (BigBlue)
no need to replace the windshield with a HUD windshield.
my HUD image is as clear (with my non HUD windshield) as my friend's '03 that came with HUD from the factory. :cheers:
To Dash cutting for hud
