Squeaky pulley at startup!!! HELP!!!
Old May 11, 2003 | 10:34 PM
darkmercury's Avatar
darkmercury
Default Squeaky pulley at startup!!! HELP!!!
My 01 coupe seems to start squeaking when warming up!!! :smash:
Any suggestions or something to cure my pain??? :confused:
Old May 12, 2003 | 12:54 AM
xelor98's Avatar
xelor98
Default Re: Squeaky pulley at startup!!! HELP!!! (darkmercury)
I use belt dressing or WD40 on the belts and it goes away. Unless it's a bigger problem that should handle it. Be careful if you this when the car is running.
:yesnod: :yesnod:
Old May 12, 2003 | 01:11 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I had this start after I did an engine detail. I isolated the squeek to the idler pully. I hit it with some silicone lube, and it's been fine since.
To Squeaky pulley at startup!!! HELP!!!
