ET streets+3.90 gears??
Old May 12, 2003 | 12:31 AM
enloe's Avatar
enloe
Default ET streets+3.90 gears??
I just installed 3.90 gears and the CCW drag setup with Mickey Thompson ET streets. What tire pressure and launch rpm should I be running? My best previous ET was 12.70 @ 111.14mph. What improvements can I expect? Thanks.
Old May 12, 2003 | 12:36 PM
kromberg's Avatar
kromberg
Default Re: ET streets+3.90 gears?? (enloe)
Did you get the harden cross output shaft installed also? If not, with the gears and tires, you will snap the stock one fairly soon. I have 3.90:1 gears, ET Streets, 3800 stall converter, and the harden output shaft; I am launching at about 3600 rpms and am getting 1.65 60' times off motor.
Keith
Old May 12, 2003 | 04:12 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: ET streets+3.90 gears?? (kromberg)
First question is is do you have line lock on the car? You really need to get some heat into those tires. I'm sure the ZO6 clutch will not last too long either.
I have seen the best results with 10-12 psi in the tires. You will have to leave higher then you think with the stick because the ET's are going to want to pull the motor down hard on launch. For example I leave at 5200 and it pulls the motor down to around 4600, where peak torque is.
Trail and error are the only real options. Everything else is just opinions!
Old May 12, 2003 | 06:21 PM
Redvette_22's Avatar
Redvette_22
Default Re: ET streets+3.90 gears?? (9D9LS1)
As mentioned, the only method that works is trial and error. I run 15 lbs (cold) in my 11.5 ET Streets and with my A4 and 4000 Precision converter it launches with 1.51-1.53 60' times.
Old May 13, 2003 | 04:53 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
4.10 in A4 with 3500 stall converter.
I have had my best success with 12 lbs warm which is about 10 cold.
To ET streets+3.90 gears??
