Differential swap - install costs?
Old May 13, 2003 | 01:17 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Differential swap - install costs?
I just bought a new 3.90 diff (outright) from another forum member.
Trying to gauge a ballpark labor time and cost estimate for installation.
For those that have had this done, how much did you pay, and how long did it take them to do it? This is just swapping the entire differential unit, not putting gears in an existing housing. And I have a 6spd car, so I don't think there's any programming needed.
Thanks in advance.
:cheers:
Old May 13, 2003 | 01:48 AM
jmzvet's Avatar
jmzvet
Default Re: Differential swap - install costs? (Y2Kvert4me)
About $500 in SoCal and takes about a half day. There's a good "how to" here on the Forum if you like getting your hands dirty.
Old May 13, 2003 | 02:07 AM
z0sense's Avatar
z0sense
Default Re: Differential swap - install costs? (jmzvet)
I did mine myself. It was actually easier then I thought.
Labor time in the book is 10 hours. I have never tackled anything like this and did it in about 6 hours.
Most people are between 400-500 bucks.
Old May 13, 2003 | 08:35 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Everything I've seen says book time is more like 6 hours. 4 is more like it with a second set of hands at the right times. Try using someone who has a few of these under their belt or you'll be paying for their learning/practicing. You are correct regarding programming.
Old May 13, 2003 | 09:42 AM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Re: Differential swap - install costs? (ToplessTexan)
Will a change in rear gear throw the speedometer off calibration?
Old May 13, 2003 | 10:24 AM
los7883's Avatar
los7883
Default Re: Differential swap - install costs? (99SilverC5Coupe)
I paid $400 for my gear/TC swap...and I believe you don't have to make any changes for the speedo...but you will want to change the shift points with LS1 Edit.
Old May 13, 2003 | 10:45 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Differential swap - install costs? (los7883)
no; and this is unique to C5 Corvettes.
Old May 13, 2003 | 07:33 PM
z0sense's Avatar
z0sense
Default Re: Differential swap - install costs? (Mike Mercury)
It will throw it off if it is an A4 correct? It was my understanding that only M6 had the ability for self calibration.
Also book time is about 8-10 hours @ 50/hr 400.00 - 500.00. That is what my understanding was.
Old May 13, 2003 | 08:05 PM
Mike Mercury
Default Re: Differential swap - install costs? (z0sense)
No. tranny type doesn't matter (talking about the speedometer only here).
Old May 13, 2003 | 08:06 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
No, it will not throw off the speedometer of an A4.
Old May 13, 2003 | 08:07 PM
1SGRET's Avatar
1SGRET
Default Re: Differential swap - install costs? (1SGRET)
Dang Mike, you beat me by a minute!
Old May 13, 2003 | 08:09 PM
ToplessTexan
No, that is not correct. The speedometer is driven off the VSS signal which measures axle rotation rate in the C5, not transmission tailshaft rotation rates as in other cars.
A $50/hr shop rate is cheap for a qualified Vette tech. Typically more like $70-75/hr around here.
Old May 13, 2003 | 08:42 PM
warpster's Avatar
warpster
Very few qualified techs around here so I was forced to take it to the Dealer :eek: Had 3.42s a TC and Tranny cooler installed........set me back $932 (about $750 labor) and 2 days. I know, I know, I'm still hurting from it!!
Where's the hang head in shame icon? :cry :cry
Old May 13, 2003 | 09:12 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Differential swap - install costs? (warpster)
450 here for gear and t/c change over plus 100 for computer work.
Old May 13, 2003 | 10:03 PM
camiv's Avatar
camiv
I paid 425 to have it done. I did not change the tc but this is the time to do it if you want a higher stall. depending on your set-up with the 3.90...you may not want the tc. They say the time is a half day job but the time only matters if you tackle it yourself.
Old May 13, 2003 | 10:49 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Differential swap - install costs? (camiv)
Tom you can do it yourself buddy. Nothing to it. Just call me if you run into a problem. :cheers:
Old May 13, 2003 | 11:39 PM
see5's Avatar
see5
It really is easy with two guys. Two guys and a lift and it might be called fun.
If you decide to DIY let me know. There are several shortcuts.
[Modified by see5, 10:42 PM 5/13/2003]
To Differential swap - install costs?
Old May 14, 2003 | 01:34 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Default Re: Differential swap - install costs? (C5-VERT)
I'm sure I could do it myself...the question is, do I really want to do it myself. :D
I do have access to a lift, maybe this is something to think about. I recall seeing a page a while back that detailed the procedure, but I didn't save the page, and really have no idea right now what all is involved. I didn't see anything in the tech tips section here, unless I missed it. Anyone know of a good how-to page for this?
Thanks all for the replies, I can swallow 500 for the install, probably will...but I am curious to see what it all entails.
:cheers:
Old May 14, 2003 | 01:42 AM
jmzvet's Avatar
jmzvet
Check this out. http://mikemercury.home.att.net/342.htm
Old May 14, 2003 | 03:30 AM
AZGASSER's Avatar
AZGASSER
Mine was 475 including all the fluids and took about 4 hours. Excellent work by Extreme!
