373 or 390 rear end?
Old May 15, 2003 | 03:09 AM
dave777's Avatar
dave777
St. Jude Contributor
Default 373 or 390 rear end?
Where is the best place to get these and what is perfered for a h/c car with about 400 rwhp? :confused:
Old May 15, 2003 | 09:56 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: 373 or 390 rear end? (dave777)
if your going to spend the money for gears go for the 3.90.
i assume this is a 6 speed car. a tire upgrade may also be required.
Old May 15, 2003 | 10:22 PM
Jack R. Stein's Avatar
Jack R. Stein
Default Re: 373 or 390 rear end? (Mr. Jones)
Go with the 3.90, and you will not be sorry! Best place to get it is from Paul at CORVETTES OF HOUSTON. Don't forget to get the heavy duty output shaft as well! Best of luck!
Old May 16, 2003 | 08:20 AM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: 373 or 390 rear end? (Jack R. Stein)
Assuming yours to be a MN6, go with the 4.10s and don't look back. As you are on the east coast, give East Coast Supercharging in NJ a call; they did mine and it has been great; no noise just lots of smiles. Not only do they do good work, they are nice people to deal with. Ask for Chris the owner and tell him I sent you. And yes, would recommend you go with the hardened output shaft as well; with it you will sleep better nights. Good luck with your choices.
Joe
Old May 16, 2003 | 04:21 PM
West Coast Corvette's Avatar
West Coast Corvette
Supporting Vendor
St. Jude Contributor '03 & '04
Default Re: 373 or 390 rear end? (C54FUN)
Go with 4.10's they are worth .3-.4 tenths over the 3.42's and they are a lot of fun to drive. I happen to have a used set for sale right now, cheap!!
http://forums.corvetteforum.com/zerothread?id=562857
Todd
parts@westcoastcorvette.com
Old May 16, 2003 | 05:16 PM
sanchez's Avatar
sanchez
Sorry to piggy back on your thread, but what are going to 4.10 gears going to do to your Top End vs the 3.42 stock rear end?
Sam
Old May 17, 2003 | 02:11 AM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: 373 or 390 rear end? (sanchez)
Do you recall what the rpm's are on a M6 car at say, 70 mph, or 80 mph? I want some gears, but don't want it screamin' on the highway. 6th gear now is almost unusable below 80 mph. When are these gears gonna come down $$$ so i can get some? :rolleyes: SCOTT
Old May 17, 2003 | 05:01 PM
C54FUN's Avatar
C54FUN
Default Re: 373 or 390 rear end? (99 The Hard Way)
Guys, in my '98 at 75MPH, I am turning 1900RPMs with the 4.10s. That's really loafing and very little engine noise. In fact, there isn't any over the Corsa Tourings.
Joe
Old May 17, 2003 | 06:15 PM
Guest
Guest
Posts: n/a
I'm gonna go with 3:73 gears if I ever change from my 3:42s. I'm not a dragger -- don't think that was what the Corvette was built for -- it's a road racing car. :smash:
Old May 18, 2003 | 03:13 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: 373 or 390 rear end? (MMI)
Personally, I think that 4.10's might be a bit much for 400 rwhp. I'd probably go with the 3.90's. But the 4.10's are fine for freeway driving and you're not really taching out that much. I think I lose about 2mpg with the 4.10's versus the 3.42's. With either of those gears, 6th will be much more useful.
Old May 18, 2003 | 09:45 PM
garry harris's Avatar
garry harris
I have a 6 speed H/C+ and debated the 3.90 vs 4.10. I had 4.10s in my 96 stroked car, they were awesome. But I decided to go with 3.90s this time. Looking to retain some economy and less wear on the engine. Either will work well but I went with the 3.90s and have no regrets at all. Got them from Paul at COH. There is not a hint of noise.
Gary
Old May 18, 2003 | 11:51 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
:iagree: I have 390s to go with the h/c and blower at about 1900 to 2000 I am going 80mph, with the 342s I was going 90, 6th gear is a usable gear and after winding out 5th you will keep pulling in 6th, 390s or 410s pretty similar, 373's are just not that much lower for the amount of money you spend. Also the car is a lot easier to drive with the lower gears and lot less slipping the clutch to take off.
To 373 or 390 rear end?
