Performance Mods Question
I have an '02 Coupe, automatic, pure stock, and I am starting to do mods with my goal to equal or exceed Z06 performance, 400+ RWHP.
I do not currently do any type of racing, on or off the street. I simply want to have a more powerful car with balanced power across the board.
I have ordered a Vararam and a Corsa TigerShark exhaust and crossover pipe. I have ordered Z06 size wheels, and I am very close to ordering the Goodyear F1 Supercar tires (chosen over Michelin Pilot Sports).
I have decided on installing ported heads and a OEM Z06 cam.
Now the problem. My car has 2.73 gears. Should I replace them with OEM 3.42 gears or is there a better alternative?
Do I need to consider an upgrade to the stock brakes?
Do I need to make modifications to the suspension?
Are the performance mods I have planned sufficient to achieve the goal of 400+ RWHP?
Are there any glaring weak spots in my plans or additional mods I should consider?
Thanks in advance for your feedback and suggestions.
:auto:
[Modified by tblair7500, 10:33 PM 5/15/2003]
[Modified by tblair7500, 10:46 PM 5/15/2003]
The wheels and tires are a great combo that IMHO you will be happy with.
I think you should change out the rear to a minimum 3.42 but would have you consider a 3.73.
you probably want to look into some kind of mod to maybe beef up your transmission.
Since you are doing heads/cam I suggest Long Tube Headers and an underdrive pulley. The pulley is cost prohibitive to install alone but should be strongly considered when all is apart for the heads/cam already.
With your mods and the others I have mentioned you will need some kind of custom tuning of your PCM.
With the tuning you can have your transmission shift points adjusted appropriately.
In my opinion without a more agressive cam and having an automatic you may not be able to attain 400 RWHP.
I think to even have a chance you will need the headers, underdrive pulley and tuning.
Best of luck to you on you mods!
:cheers: :smash:
[Modified by chucschramm, 10:58 PM 5/15/2003]
You are right for getting the exhaust, airbox, and heads (although not needed to get 400). However I would get a slightly more agressive cam then the stock one like a TR224...etc! You will need tuning and such to make it idle properly, but it will be worth it!
I would definately get 3.42's although I believe the 2.73 will provide higher numbers on a dyno:)
You do not need to do brakes, unless you want to, and in any case I would get the Eradispeeds or the AC delco, slotted and cross drilled!
