Sorry to ask what must be a newbie question - I couldn't turn up the answer in a search.
I wanted to ask - do all C5 rear diffs interchange? i.e. can a guy with an A4 bolt on a diff from a C5, and there's nothing to worry about interchanging?
Fellow with an A4 is selling his 4.10 rear diff, and I was curious if it was a 100% bolt on to my MN6 car.
Re: Are all C5 differentials interchangable? (JakeL)
Actually what you want to do with the 4.10 diff will work. I believe Diff's are interchangeable but ring and pinions are not. Stock 2.73 ring and pinions are not interchangeable with any higher ratio. 3.15 carriers and 3.42's can be upgraded. I'd double check before buying if you've got the 2.73 carrier.
Hi I have a C5. 2004 it was stick I change to Automatic 2.73 I have problems with the gears I put the 3.42 from the stick what can I do is kicking 1 and 2 gear in the trasmition the computer is given me code P0894 please any one can help me
