Had intake manifold off, now throwing codes Please Help!!
Old May 17, 2003 | 08:29 PM
lofarris's Avatar
lofarris
I checked again for any loose connections but didn't find any. But, when I started it again the check engine light was not on. I guess it just needed some time to reset itself.
Thanks for all your help.
[Modified by lofarris, 3:44 PM 5/18/2003]
Old May 17, 2003 | 08:43 PM
jawsski's Avatar
jawsski
Default Re: Had intake manifold off, now throwing codes Please Help!! (lofarris)
P0107..manifold absolute pressure MAP sensor circuit low voltage
p1120..TP sensor 1 circuit-A
p1220..TP sensor 2 circuit-A
p1514..TAC system MAF performance - A
p1566..???? are you sure its not p1516 which is..command vs actual throttle position performance(TAC module) - A
Looks like something around the throttle body check for vacuum leak
Old May 17, 2003 | 08:44 PM
RichS's Avatar
RichS
http://www.c5-corvette.com/IPC_Codes.htm For a list of codes. Did you put the vaccume lines all on in the back? My guess would be a vaccume leak.
Old May 17, 2003 | 08:46 PM
jawsski's Avatar
jawsski
Default Re: Had intake manifold off, now throwing codes Please Help!! (RichS)
did you remember the little black vacuum tube at the back of the manifold? why the hell GM put it there ????
Old May 18, 2003 | 04:36 PM
hot4u's Avatar
hot4u
Default Re: Had intake manifold off, now throwing codes Please Help!! (jawsski)
Check all the wires make sure everything is connected back together. Had mine replaced by the dealer got it home and the check engine light came on. started throwing codes. went under the hood and had to wiresthat were not connected back buy the dealer, reconnected the wires reset the dic no more problems.
Old May 18, 2003 | 05:02 PM
SpinMonster's Avatar
SpinMonster
I almost missed that little tube also. It is very thin....looks like a tiny straw. :thumbs:
Old May 18, 2003 | 06:24 PM
lofarris's Avatar
lofarris
Default Re: Had intake manifold off, now throwing codes Please Help!! (SpinMonster)
I think I got that little tube. Boy was that fun!!! I had to pull the manifold forward about an inch to fit my hand back there. After I would get in lined up, it would come out after I slid the manifold back into place. That was a fun 20 minutes, I had a few choice words for whoever put it there.
To Had intake manifold off, now throwing codes Please Help!!
