Finished the decarb process... observations and some questions
I did the engine decarb process a few days ago complete with an oil change. The car runs great and for some reason is running cooler, noticeably cooler... don't know why.
The process was quite easy, the only nerve racking part is pouring the liquid into your engine. Besides that, it was pretty easy. Replaced the oil with 10W30 Mobile 1 and a UPF-44 filter. Throttle response is improved and there is no more pinging. The PCV mod was done a few weeks before this so I am protected against any oil vapor from the PCV line.
My only question is changing the plugs. I just put new plugs and wires on about 3,000 miles ago. Does the decarb process foul spark plugs? Should I replace them again?
Re: Finished the decarb process... observations and some questions (Patman36)
If I may; yes, the plugs could get fouled but you said it's running great so I wouldn't worry about them. If they start to misfire, just do "an Italian tune-up"....a few WOT blasts in each of the gears. :D
Removing the carbon from the combustion chambers removes potential 'hot-spots', allowing the eng. to run "cooler"--at it's normal operating temp.
Where did you get the TEC? I went to the local dealer last week, and they looked at me like I was crazy, then said "GM doesn't distribute that any more." :rolleyes:
Re: Finished the decarb process... observations and some questions (pmarone)
For what its worth, I bought the last can that Power Chevrolet in El Segundo had. Counter man told me they can no longer sell it in CA. due to environmental issues.
Re: Finished the decarb process... observations and some questions (vetdaddy)
Pete, I actually ordered it from Ken Fichtner Chevrolet (supporting dealer/vendor). It was something like $5 per can. My local dealer sold it too but for a little more. Wonder why they said GM doesn't distribute it any more? Maybe just in California?
Just a FYI comment, but back in the "stone age" the 60's, we used to drip a bit of water into the carb, holding the rpm at about 2000, you would be amazed how well steam cleaning works on carbon build-up, just a few drops at a time. Ric
Re: Finished the decarb process... observations and some questions (Power Shifter)
Also just so you guys know, the same stuff GM sells as TEC, is sold by another company. The product is called Sea Foam and is only available from Napa Auto Supply (to my knowledge). I have used it before, works great and probably still available here in CA. The bottle (can) is extremely plain looking and wont stick out as anything special.
:iagree: In fact, I've even done it in the '90s !!
Re: Finished the decarb process... observations and some questions (pburant)
Don't some mechanics just use ethyl glycol to decarb engines?
:banghead: Ethyl on a an engine can be very bad news. It is usually used only if the engine has been off for too long (especially in the cold) and a small spray is used as starter fluid. Dont use that to clean your engine.
Do that to my bro's '88 just about every other year. I connect a gallon jug of water to one of the plenum vacuum lines and let it suck the water through. Cures the knock / pinging problem with his engine.
