A4/3.42 Shift Point Recommendations
Old May 21, 2003 | 06:23 AM
78Vette-SA's Avatar
78Vette-SA
Default A4/3.42 Shift Point Recommendations
Could anyone who swapped out a 2.73 for 3.42 recommend shift points to reset it at. I have a HPPIII but need to get some suggestions.
Old May 21, 2003 | 02:58 PM
Steve98TransAm's Avatar
Steve98TransAm
Default Re: A4/3.42 Shift Point Recommendations (78Vette-SA)
Although my car is an F-body, I believe the A4 transmission ratios are the same. With the 3.42's in my car now, I have my 1->2 shift set at +1, and my 2->3 shift at +1 also. I left 3->4 stock.
My car will tap the limiter (6200 on a stock F-body) a single time on the 2->3 shift every now and then, maybe a total of 3 times in the 5,000 miles since I did the 2.73->3.42 swap. The only times it has happened was when I was at the dragstrip, otherwise I'm not doing any WOT runs fast enough to hit the limiter on the 2->3 shift, I don't want to risk getting a speeding ticket.
Hope that helps a little bit. :)
[Modified by Steve98TransAm, 3:00 PM 5/21/2003]
Old May 21, 2003 | 10:18 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: A4/3.42 Shift Point Recommendations (Steve98TransAm)
Thanks for the tips.
To A4/3.42 Shift Point Recommendations
