Need Help Diagnosing a Problem
Old May 22, 2003 | 01:07 PM
TT BD's Avatar
TT BD
Default Need Help Diagnosing a Problem
Guys,
I have a Zo6. Please read this chain of events and help me come up with a diagnosis of the problem.
1. Had just taken a 40 minute trip. Stopped to get gas. When I went to start the car, the entire dash was out (instrument cluster, radio, and AC...all shut down) as well as the engine and power seats!...After a few turns of the key, the car eventually restarted, but instruments didn't come back. I drove it for about a 1/4 and the engine shuts down again. Finally got it going again and went home.
2. Next day, as I pulled in to get gas (driving alot), the dash went out again, but engine ran.
Any help would be GREATLY appreciated. :banghead:
Old May 22, 2003 | 01:33 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Need Help Diagnosing a Problem (TT BD)
check your ignition switch. Make sure the key is firmly seated in the correct position.
Old May 22, 2003 | 01:56 PM
jojog's Avatar
jojog
Don't mean to be insulting but did you check the battery connections (both terminals and at both ends). With a plastic car, grounds are scarce! :thumbs:
Old May 22, 2003 | 03:11 PM
lyonsh's Avatar
lyonsh
I'd suspect a ground problem. I'm not where I can get to my shop manual right now, but I'd start by looking for a ground common to all those. They do come loose.
Good luck. :cheers:
Old May 22, 2003 | 04:00 PM
TT BD's Avatar
TT BD
Apparently, the dealership said the codes came back clean. :confused:
To Need Help Diagnosing a Problem
