wind noise
Old May 23, 2003 | 01:00 AM
adios-1's Avatar
adios-1
Default wind noise
Posted previously and forgot to inquire about the wind noise I experience at 60 mph and up. I have read some of the comments but none seem to speak specifically to this problem. The noise is coming from the driver and passenger windows at the point where the windshield, top and window meet. I have isolated the noise to the window(not the top) and it appears that the windows need to be tilted in just a little to make for a better seal. Problem is that I can't figure out how difficult it will be to try to remedy myself as opposed to putting in the shop. How do you adjust the tilt of the windows? Is it a major ordeal or a simple task? Anybody experience the same? Thanks in advance for the advise.
Old May 23, 2003 | 12:16 PM
c5&r1 4fun's Avatar
c5&r1 4fun
Default Re: wind noise (adios-1)
any input would be appreciated
i also have some sort of leak at the seal at speeds over 70 mph or so
is this a common problem
with an easy do it yourself solution?
Old May 23, 2003 | 12:21 PM
01SS's Avatar
01SS
mine gets a little noisy above 140mph :D
Old May 23, 2003 | 12:22 PM
racetchr's Avatar
racetchr
Have had 3 C5's and they all have had wind noise and a little leak from time to time in heavy rain. You get used to it!
Old May 23, 2003 | 01:45 PM
ryanc440's Avatar
ryanc440
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Re: wind noise (racetchr)
This website has some really good info on fixing wind noise. http://www.***-internet.com/johndennington/how_to/how_to.html
It specifically addresses how to tilt the windows in and out by adjusting some components in the door. Hope it helps, I plan on trying this with my coupe this weekend. :seeya
Old May 23, 2003 | 02:00 PM
DaveM's Avatar
DaveM
I had this problem with mine on the driver side. At speeds above 60 mph a special wind leak noise would intrude in a very obvious way. Rain made a strange sound too. It wasn't the normal wind along the window noise. It was located at the top front corner. The window needed to be lowered a 1 mm or so and the tip-angle needed to be adjusted inward 2 mm or so. I had the dealer body shop fix it. Do a search here on window tip in angle. One post explained how it works very well and you'll be able to look at your window and see if it matches the problem (top edge showing). My car sounds fine now at over 90 mph with normal wind sound, no screaming leaks (don't ask me how I know... ;).
Old May 23, 2003 | 05:24 PM
adios-1's Avatar
adios-1
Default Re: wind noise (ryanc440)
tried the web site but no go. can't pull it up. is the cite accurate? is there any other way to pull up the info? I appreciate your help.
Old May 23, 2003 | 06:08 PM
Miaugi's Avatar
Miaugi
Try this!! :)
http://www.***-internet.com/johndenn...ow_tip_in.html
[Modified by Miaugi, 6:13 PM 5/23/2003]
Old May 23, 2003 | 06:33 PM
ST-rider's Avatar
ST-rider
I get wind noise on the passenger side also but I'm not sure
if it's from the front or back. If I change the fan from
"outside air" to "recirculate" the noise will go away.
That little bit of pressure makes a difference.
Also, I've noticed that when I put the roof panel on, sometimes
the rubber molding at the back corner of the window
will get tucked in wrong.
Old May 24, 2003 | 12:39 AM
adios-1's Avatar
adios-1
Default Re: wind noise (Miaugi)
Got it...thanks. I plan on trying this out.
To wind noise
