Does anybody know where is the Oxygen Sensor cable locate at? because I need to connect my signal cable from my Air/fuel gauge to. Thanks... :confused:
There is actually two places you can connect.
1. you can purchase a pigtail and connect directly to the o2 sensor.
2. There is a wire on the ecu (purple with grey stripe) that you can connect to. I am not sure of the wire number, but I am sure that one of the 2 wires is purple.
