Wandering C5 under braking. Could use some help.
Old May 24, 2003 | 12:35 PM
bcresc's Avatar
bcresc
Default Wandering C5 under braking. Could use some help.
My ’99 Coupe tends to wander under braking when on uneven surfaces. It does not consistently pull to the left or right, but wanders depending on the road surface. I just had it aligned at my Chevy dealer and nothing unusual showed up. The car goes straight down the road, even under braking, when the road is smooth. By the way, the car has 20K miles and decent tires. Any help is appreciated. Thanks, Bob
Old May 24, 2003 | 05:08 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Wandering C5 under braking. Could use some help. (bcresc)
Unless it is excessive this is what happens when you have low profile, wide tires on a relatively light car. I have one place North of me where I really have to watch it as the pavement is very grooved right in the middle of the braking area. It definitely pulls the car off of a straight line.
Runflats make this effect worse. (Very stiff sidewalls)
Bad brakes or bad alignment would cause this to occur all the time, even on smooth roads, which is not what you describe.
Old May 25, 2003 | 01:58 PM
gstama's Avatar
gstama
Default Re: Wandering C5 under braking. Could use some help. (Richin Chicago)
You should make sure the castor is set even and at least 6.7 positive and higher is better it will make a huge difference, I find most alignment shops dont care so i always watch them do it or i go somewhere else. If you have realy big tires that will hurt stability a bit.
:blueangel: :grouphug: :auto: :party: :cool:
my daughter like's the forum too
[Modified by gstama, 12:59 PM 5/25/2003]
Old May 25, 2003 | 07:44 PM
Cirrus8's Avatar
Cirrus8
I have an 01 coupe and it wanders when the surface is uneven but I am not concerned because it tracks true on smooth surfaces. As has been said in the responses above, it has to do with the wide tires, stiff side walls, and light weight of the car. I would not worry about it. :D :D
Old May 25, 2003 | 08:03 PM
warpster's Avatar
warpster
Default Re: Wandering C5 under braking. Could use some help. (Cirrus8)
I agree...when I first got my 2002 I thought the same as you, that something was wrong but as I was told at the time and as I beleive now...it is normal.
Old May 25, 2003 | 10:03 PM
SHOWTIME!'s Avatar
SHOWTIME!
wide tire catch the road's imperfections
Old May 26, 2003 | 12:05 AM
CDad98's Avatar
CDad98
1st Gear
Just fixed that problem (based on how your description sounds) this weekend on my 98. I bought the car with 20K miles and it was very subtle, but became gradually worse as the miles accumulated. I changed out the front brakes and discovered significant uneven wear between the driver and passenger side pads. Had the rotors turned, replaced the pads and is now smooth as a baby's butt under all braking conditions.
Old May 26, 2003 | 08:24 PM
eaa1964's Avatar
eaa1964
I too experience this problem on my 99 coupe with daily run flats. For travel to autocross, I switch to my alternate rims/Kumhos...this wandering goes away. I agree that the run flats do funky things on semi-truck warn roads.
To Wandering C5 under braking. Could use some help.
