Blackwing question
Old May 24, 2003 | 06:00 PM
LS7's Avatar
LS7
Default Blackwing question
Is it true that the Blackwing air cleaner will allow dust to enter into the engine over time due to it's high flow rate? Do they sell a cover for the Blackwing? Will the hoodseal be enough to prevent unwanted dust particles from getting past the filter? :confused:
Old May 24, 2003 | 09:13 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: Blackwing question (LS7)
The Blackwing is an efficient filter - if you keep it cleaned it will keep dust/dirt out of your engine.
Old May 24, 2003 | 09:44 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
1) Should be fine if you oil it properly.
2) Get the hood seal, it'll help.
3) Don't worry about it.
Old May 24, 2003 | 09:56 PM
JWD01's Avatar
JWD01
Default Re: Blackwing question (Bob Chapman)
Actually the Blackwing is made from the same material as the K&N filters and they filter better when they are dirty(not filthy). :cheers:
Old May 24, 2003 | 11:05 PM
Double Aught's Avatar
Double Aught
Default Re: Blackwing question (JWD01)
Can I use the K&N filter wash with a Blackwing?
Old May 25, 2003 | 12:39 AM
MagRed2002's Avatar
MagRed2002
Donaldson (the manufacturer of the Blackwing) has been in the high end truck air filter business for years. Their reputation is impeccable. The Blackwing's high flow will not result in increasd particulate "pass-through" - more likely the opposite, given the fact that the filter media is significantly more sophisticated that the stock paper element.
Regarding the hood seal, all that does is alter the flow of air within the underhood compartment. It will have no impact on filter efficency.
Old May 25, 2003 | 01:54 PM
DAWS C5's Avatar
DAWS C5
Default Re: Blackwing question (sd pacecar)
Actually, the Blackwing is made of synthetic media and are not the same as K&N which are cotton gauze media. Do not use the K&N cleaner on Donaldson! I use only Donaldson cleaning products but I've been told by the vendor (Exit 28) that Simple Green cleaner and Mineral Oil are ok.
:seeya
Old May 26, 2003 | 08:38 AM
AFVETTE's Avatar
AFVETTE
Donaldson knows something about filtering in nasty enviroments. They supply all the filters used on our main battle tanks and personnel carriers as well as other military vehicles. If you saw the enviroment our military hardware has to play you will appreciate their expertise.
Tom
USAF Retired
To Blackwing question
