Replacing stock auto shift knob
Old May 24, 2003 | 10:52 PM
Cirrus8's Avatar
Cirrus8
Default Replacing stock auto shift ****
I recently saw a classy brushed aluminum **** on an A4. Does anyone know where it can be purchased? This **** did not have the button on top so I assume that the shaft must also be changed so that the entire **** can be pushed down to get past the detents. :D :D
Old May 25, 2003 | 12:01 AM
Purerock105's Avatar
Purerock105
Default Re: Replacing stock auto shift **** (Cirrus8)
Check the forum mall to purchase. To install you have to screw on
an adapter that attaches to the shaft, then when the actual **** is
is on you simply depress the ****. When buying most of these
replacement shifter ***** all the parts you need 'should' be included.
:cheers:
Old May 25, 2003 | 09:24 AM
wineguy's Avatar
wineguy
I have one.Works great :yesnod: I bought mine from Exit28.Different colors are also available.
To Replacing stock auto shift knob
