CD changer operation/installation????
Old May 27, 2003 | 05:31 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: CD changer operation/installation???? (Ram Air Tony)
Hi there,
Once you remove the changer from the brackets, then its not really bad, just remove the phillips screws from the black cover at the back of the changer. Then, pivot the cover up, as the tabs retain it to the front cover.
You will see the release tab at the back, top area.
Allthebest, c4c5 :banghead:
Old May 28, 2003 | 08:27 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: CD changer operation/installation???? (c4c5specialist)
OK.........I will peel the skin on that bad boy and see if I cant remove the magazine
thanks for the assistance !!!!!!!
R
A
T
