1st gear problem!
Old May 25, 2003 | 04:20 PM
BHulsey's Avatar
BHulsey
Default 1st gear problem!
I've got a black 2000 hardtop with about 4750 miles on it. Only about 5 thousands of those miles are mine. Well, since a got it, every once in a while it would kick out of 1st and go into neutral. Well, yesterday it did it three times, and it was a more violent kick into neutral. What should I do?
Old May 25, 2003 | 05:01 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: 1st gear problem! (BHulsey)
Are you sure you are fully in first when you start out? These cars have a fairly "notchy" shift gate and it takes a bit to make sure the shift is all the way up.
Old May 25, 2003 | 05:41 PM
Gene K's Avatar
Gene K
Default Re: 1st gear problem! (Richin Chicago)
Assuming it is fully in gear, work clutch in and out partially to make sure it is fully seated, check gear shift linkage for proper adjustment.
Old May 26, 2003 | 12:43 AM
racetchr's Avatar
racetchr
I have a '00 and thought the tranny was bad at 500 mi. It jumped out of gear so often I was ready to have dealer replace. A forum member told me to change to Redline synthetic fluid and I was amazed at the difference. Car has more miles than I care to share - but it shifts a smooth as glass and has not jumped out of 1st gear once since changing fluid. Do it! You won't be disappointed.
To 1st gear problem!
