Power Door Lock Problem
Old May 26, 2003 | 01:57 PM
JLinCA's Avatar
JLinCA
Default Power Door Lock Problem
Hi All,
I'm started to have intermittent problems with my passenger side power lock. I've read previous posts where the problem was attributed to a faulty switch or the electronic module.
Is it just a matter of replacing the switch assembly, or is there something else in the door that needs to be replaced??
Old May 26, 2003 | 02:15 PM
dave777's Avatar
dave777
St. Jude Contributor
Default Re: Power Door Lock Problem (JLinNY)
I had the exact problem with my 02 I took it to the dealer and they fixed it the same day (warranty). I am not real sure what they did but I will give them a call and find out.
Old May 26, 2003 | 02:20 PM
kenrobb's Avatar
kenrobb
GM replaced the entire lock control module on my 99 with same problem you have. It is not repairable. sort of a common problem at times.
To Power Door Lock Problem
