Shift Knob Replacement
Old May 27, 2003 | 11:16 AM
Sabby's Avatar
Sabby
Default Shift **** Replacement
Hello,
Does anyone know how to take off the stock shift **** on a 2003 6-speed? :flag
Old May 27, 2003 | 11:43 AM
Patches's Avatar
Patches
Default Re: Shift **** Replacement (Sabby)
Check out the Tech Tip link below.
https://www.corvetteforum.com/techti...D=34&TopicID=1
Old May 27, 2003 | 12:52 PM
Sabby's Avatar
Sabby
Default Re: Shift **** Replacement (Patches)
Thanks Patches!
:thumbs:
Old May 28, 2003 | 05:15 AM
CR555's Avatar
CR555
The hardest part of the procedure is getting the retainer pin out. It's a kind of T-shaped key that prevents the shift **** from turning loose. Be sure not to damage the pin, since it is only made of very mild steel!
If you experience any problems, let us know! :grouphug:
Old Jun 2, 2003 | 01:15 PM
Sabby's Avatar
Sabby
Default Re: Shift **** Replacement (CR555)
I can't get the retainer pin out. It is in there soooo good. Is there any type of tools that would help?
:confused:
Old Jun 2, 2003 | 01:38 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Sabby, I've always had good luck using the 2 big blade screwdriver method. Hold a screwdriver on each side of the retainer pin, and fulcrum it out (like those corkscrews). This is a little hard to explain, but the back of the pin (i.e., facing the rear of the car) has a little shoulder on it (you'll see what I mean after the fact), so when you place the screwdrivers in position, place the rear edge of the screwdriver just forward of the rear edge of the pin, to clear this shoulder. This will maximize the amount of surface area you have to pop the pin out. Good luck.
Old Jun 2, 2003 | 05:28 PM
MVP's Avatar
MVP
This helped me when I had a tough time http://forums.corvetteforum.com/zerothread?id=532098
Old Jun 3, 2003 | 02:49 AM
MagRed2002's Avatar
MagRed2002
From what I've gathered, some are tight and some are DAMN tight. I got mine out using the vice grip method - Where you clamp vice grips on the "Demon" key and pry on the vice grips with a screwdriver (being careful not to damage the leather **** by using a rag for protection).
There are some unbelievable stories out there about the tenacity of that pin - Good luck!
Old Jun 6, 2003 | 01:13 PM
Sabby's Avatar
Sabby
Default Re: Shift **** Replacement (MagRed2002)
Thank you everyone! I got the sledge pin out last night. I replaced the stock shifter with a shift **** from Team Voodoo.
Great product. Check their items out on: http://www.teamvoodoo.com :hurray:
[Modified by Sabby, 6:14 PM 6/6/2003]
Old Jun 9, 2003 | 07:38 PM
95autoLT1's Avatar
95autoLT1
Do you want to part way with your stock ****??? :cheers:
Old Jun 10, 2003 | 01:46 PM
Sabby's Avatar
Sabby
Default Re: Shift **** Replacement (95autoLT1)
I never gave it any thought. Maybe I'll keep it as a trophy for being able to get the thing off!
Did you have any suggestions for it? :flag
Old Jun 10, 2003 | 02:04 PM
sboxster's Avatar
sboxster
I have the stock one too if your interested.
Old Jun 10, 2003 | 03:25 PM
95autoLT1's Avatar
95autoLT1
Default Re: Shift **** Replacement (sboxster)
How much do you want for it?? :cheers:
To Shift Knob Replacement
