Help! IPC Function Code Failure
Old May 27, 2003 | 04:31 PM
Josvet50's Avatar
Josvet50
Default Help! IPC Function Code Failure
Per the advise of forum members I attained the IPC Function codes my car is sending relating to my operation problems with the V-Ram cold air system, and Granatelli MAF sensor I installed on my 03 LS1 6 speed coupe. The codes are P0101 Mass Air Flow (MAF) System Performance. P0171 Fuel Trim System Lean Bank 1-B and P0174 Fuel Trim System Lean Bank 2-B. Based on information I have been reading, these problems seem commonly related to the interaction of these two systems. I have decided to switch back to my stock MAF sensor. I want to keep the V-Ram however along with the high flow Air bridge and coupler. Will deleting the Granatelli MAF sensor and switching back to the stock unit work without resending the same codes? Also is it ok to remove the honey comb screen on the stock unit for more performance?
Please advise this has been quite an experience...... :boxing
