I lowered my car to just whatever height the stock bolt will allow. After turning the bolt all the way on the front end on both side, I noticed the height is markedly different much lower on driver side. In the back it's just the opposite. Drove around hundreds of miles, NO diff. I had hope it would equalize somewhat after the suspension settle down.
I then attempted to raise the driver side back up. NO luck, it won't go up. I keep turning the bolt ( driver side ) until it is now at the original factory setting but the driver side is still much lower than the passenger, this even after I cut 1/3 of the bushing on the passenger side.
I was able to get the rear to approximate somewhat.
The front end baffle me , ANY IDEAS ??? :confused: :confused: :confused:
Yea - mine did the same to me and if you can - put a jack under the arm and make the suspension flex ALL THE WAY to it will help it settle. Mine settled only after many miles on the road.. (hard turns etc)
