I just got a set of Stainless Works headers, Random Tech cats & X-pipe from Xtreme. THANKS NATE!!! :thumbs:
What header gasket should I use?
What header bolts should I use (factory?)?
I used new stock gaskets and stock bolts with no leaks or problems.
There ya' go. That's what I'd do. Stock metal gaskets are pretty good. Bolts are only torqued to 18 ft. lbs. so the originals are fine or buy a new set if you're so inclined.
When do these go in, Scott?
Shooting for the 14th of June... Where should I get the gaskets???
I have the same headers. Did you get the 1/4 inch flange or the 3/8. If you got the 1/4's then you will have to put a thick washer like a lock washer on the bolts. Otherwise the bolts will be to long. The stock manifold flange is much thicker. Also if you have problems with them leaking then I have a part number for an extra thick "Mr Gasket" that works really good, I had to use it myself.
Looks like I have the 1/4 flanges. How thick of a lock washer did you use??? What was the part# for the Mr. Gasket thick gasket???
Thanks,
:cheers:
Patches,
Hey Ed, I will let you know exactly when. I am using Mike's (mfrnka) lift. He lives near you... :D
