Bilsteins on the rear only?
Old May 29, 2003 | 07:45 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Bilsteins on the rear only?
I got some new rear Bilstein shocks for the rear of the vette. Will it hurt to only run the rear with the stock C5 shocks up front? I have the upgraded/selectable suspension. Thanks in advance for the advice. :yesnod:
Old May 29, 2003 | 08:38 AM
StickTail's Avatar
StickTail
Default Re: Bilsteins on the rear only? (ccajun4real)
Bad idea.
You need to match the front and rear. Otherwise your car will not be balanced.
It will try to swap ends.
That is not a good thing.
Suspension needs to be engineered as a complete package.
Old May 29, 2003 | 09:00 AM
adrnln1's Avatar
adrnln1
Default Re: Bilsteins on the rear only? (fdupny)
ccajun, I bought all four but ran out of time half way through the install and only had them on the rear. The front and rear were fighting each other. The car drove, but you could feel that the balance was WAY off.
Hope this helps!
Old May 29, 2003 | 09:12 AM
tlaselva's Avatar
tlaselva
Bad idea.
:iagree:
Old May 29, 2003 | 12:08 PM
0Cajun @ Edgyvette
Former Vendor
Default Re: Bilsteins on the rear only? (adrnln1)
THANKS TO ALL for the advice :thumbs: How much will it cost me to get these installed? I have no idea about shocks since I have never had to replace any. My car has 50k on it. Do I need to replace shocks? Can I let the shocks sit in the garage until I need them? Is there a shelf life on them?
Thanks :flag
Old May 29, 2003 | 01:38 PM
StickTail's Avatar
StickTail
I have done it a few times.
Pretty straight forward.
Last time I took pictures and refined my technique.
I will do a writeup soon.
I will keep you posted. :thumbs:
Old May 29, 2003 | 02:22 PM
adrnln1's Avatar
adrnln1
I installed mine in my garage, car up on stands, remove wheels, remove bolts, jiggle out, jiggle in same way and voila. Took about 2 hours total time.
To Bilsteins on the rear only?
