Headers vs. no cats
Old May 29, 2003 | 10:01 AM
Red5's Avatar
Red5
Default Headers vs. no cats
This is an area that I am having trouble understanding the basic concepts of air flow.
I look at it as restriction (aka Drag) from having air blow through your motor. Instead of bringing you into my warped thinking let me just ask a basic question.
I want more torque. You can see the mods I have in my signature. l am currently running the stock header system with a flowmaster exhuast. I just took the last VET test I ever have to take and am considering removing the cats to get more flow.
Will this give me more power? How does it differ from a flow perspective from using headers?
[Modified by Red5, 9:02 AM 5/29/2003]
Old May 29, 2003 | 10:04 AM
Red5's Avatar
Red5
Default Re: Headers vs. no cats (Red5)
For some reason my signature isn't coming through.
I have stage 2 heads and a GTP cam 226/226/112 and the flowmaster. I also have intake mods.
Old May 29, 2003 | 11:25 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Removing cats will get you some low end torque, but will make your car qutie a bit louder and not having them can produce a pretty strong exhaust smell as well.
If I was to choose between Long Tube Headers or removing the cats on a car with your mods, I would DEFINITELY go with the Long Tube Headers as you are holding back a large amount of power with only running stock exhaust manifolds with your heads/cam package.
[Modified by MattG, 11:37 AM 5/29/2003]
Old May 29, 2003 | 11:55 AM
Red5's Avatar
Red5
Default Re: Headers vs. no cats (MattG)
Thanks Matt. And thanks for the CCWs, they are going to good use.
I noticed you switched headers on your ride? What made you switch?
Are you selling the old headers?
Old May 29, 2003 | 12:52 PM
DS's Avatar
DS
you are limiting the power a lot by having stock headers. If you switch to some long tube headers, you will gain some hp and a lot of low end tq. You could go with some mid lengths, but the LT's are better for low-end numbers. With high flow cats you would be able to quiet down the car a little with headers, but you would lose more tq than hp with any cats in place.
Old May 29, 2003 | 01:19 PM
Sean03's Avatar
Sean03
Default Re: Headers vs. no cats (DS)
another problem is the flowmasters. those are the worst flowing hi performance muffler you can buy. they sound great but they dont flow crap. thats why they will never give you cfm numbers for thier mufflers they will try giving some crap about power pulses cant be measured in cfm.
Old May 29, 2003 | 02:37 PM
Red5's Avatar
Red5
Default Re: Headers vs. no cats (Sean03)
So are you guys saying to get LT Headers AND remove the Cats?
Old May 29, 2003 | 02:48 PM
Bytes U's Avatar
Bytes U
Cruise-In II Veteran
Cruise-In III Veteran
Leave the cats on.
Old May 29, 2003 | 02:49 PM
Red5's Avatar
Red5
Default Re: Headers vs. no cats (Bytes U)
OK, Why?
:confused:
Old May 29, 2003 | 02:56 PM
DS's Avatar
DS
if you want the most performance, yes get rid of the cats, but if you want to be "legal" get some high flow cats and with a good set you should only loose ~6 rwhp and 8 tq. which is not much. But you will gain a lot with the longtubes.
Old May 29, 2003 | 03:20 PM
wwashing's Avatar
wwashing
:iagree:
And, your car won't stick or give you lung cancer! :cheers:
Old May 29, 2003 | 03:53 PM
DS's Avatar
DS
Default Re: Headers vs. no cats (wwashing)
I like the no- cat smell :D
Old May 29, 2003 | 05:00 PM
c5 devil's Avatar
c5 devil
No smell here..had the cats removed 6 months ago....good luck
Old May 29, 2003 | 05:47 PM
Big Casino's Avatar
Big Casino
Default Re: Headers vs. no cats (c5 devil)
:iagree: It's been about 9 months or so for me. No smell at all. Dump that dead restricted weight.
Old May 29, 2003 | 10:54 PM
ZZ's Avatar
ZZ
Cruise-In I Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
Default Re: Headers vs. no cats (Big Casino)
I've not noticed any odor either with gutted cats. I'm going to try getting rid of the cat boxes completely and replace with larger straight pipes to see if some of the resonance and volume is reduced. Someone else posted a significant reduction in resonance by doing this.
Old May 30, 2003 | 02:15 AM
Stellar112's Avatar
Stellar112
I removed my cats going with 3 inch piping in its place, for my coupe it actually smoothed out the exhaust tone and decreased the resonance. I am running the Borla XR-1 system which IMO flows extremely well, to me though it seemed like there was still a lot of backpressure, so I removed the cats. I may be lucky, but I haven't experienced any exhaust smell and now the exhaust sound is incredible.
Old May 30, 2003 | 01:01 PM
Red5's Avatar
Red5
Default Re: Headers vs. no cats (Stellar112)
Will I need similators if i remove the cats?
To Headers vs. no cats
Old Jun 3, 2003 | 04:13 PM
2001 Red Coupe Bandit's Avatar
I just got a TC/gears, and a CAM, see sig. I don't have LT Headers, but my friend tells me to cut off the cats and put an off road X-Pipe in their place and forget teh Headers for now. he says they are a waste of $$. He said If I cut the cats off and tune it (which I will be able to tune it with LS! Edit) I should pick up 10-20 RW TQ and my car will feel so much faster. I could use the $1,200-$1600 I was going to spend on LT headers toward Heads and that would be a wiser choice in terms of HP per Dollar$$$.
I know it will be loud, but some have said it made their car sound better and actually reduced ressonance. I could always swap out my Corsa Indies with someone who has Touring to tame down my sound.
The Bandit..................
Old Jun 4, 2003 | 01:14 AM
Big Casino's Avatar
Big Casino
In the 9+ months I have not seen code #1. On my Mustang I had to get Sims to get the Check Engine Light to go off. Not on the Vette. :D
Old Jun 4, 2003 | 01:30 AM
c3dreamer03's Avatar
c3dreamer03
Well this is FAR, FAR, FAR, out of Vette territory but it may help some. I have a 92 350 Silverado with Pacesetter shorty headers, no cat, and a Flowmaster 40 series. I had the cat removed about 6 weeks ago and I put the headers on about a week ago. I couldn't really feel much "seat of the pants" wise with the cat removed. I'm sure it allowed a little more power travel to the wheels though. After I installed the headers I could really feel some new torque.
If you are debating between cat removal and headers, go with the headers FOR SURE! That cam will appreciate a pair of LT's in my opinion.
