How hard is it to change your own rotors. Looking at some slotted rotors and would like to try the install myself, a certain since of pride in that I guess! :banghead: I also like the look of bloody knuckles! :lol: Any advice, directions or links would be appreciated! :seeya
I have changeed many on various cars. The only caution I will tell you is the service manuals tell you not to use air tools. I believe it is to not snap off any off the heads. Also manual tell you to buy new bolts. A few weeks ago I did mine. New bolts all around, everything done by hand. Total time front and rear 2 1/2 hours which include raising the car and removing the tires. Dont forget to open brake fluid tank and watch level when comprising the pistons.
Do you have the part # for the 21 mm large bolts that hold the bracket?
Thanks!
The only caution I will tell you is the service manuals tell you not to use air tools. I believe it is to not snap off any off the heads. Also manual tell you to buy new bolts. Thanks!
GM part number for the large bolts that mount the calipers (2 bolts per caliper) is:
14084051
As far as using air toolss ... I have the shop manual and there is NO warning that I can find against using air tools. These bolts require 125 lb. ft. of torque, so getting 'em on and off by hand is real work, but I have done it, so it is possible!!
The manual DOES specify that you use new bolts every time you remove them.
Unfortunately I am on vacation on the east coast. Dont have service manuals with me, or coupe (boo hoo), but when I get back I will double check and I am pretty certain it mentions not to use air gun. I know it does not want you to use one when putting on or removing the wheels.
If I am way off I will let you know when I get home.
