Differences between C5 & Z06 Stabilizer Packages
Old May 31, 2003 | 05:48 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Differences between C5 & Z06 Stabilizer Packages
I was wondering if there are any major or noticeable differences between the two? Was thinking of upgrading to the Frt & Rr Z06 Stabilizer Bars, Frt & Rr Aluminum End Links, Frt & Rr Bushings?
Is it worth to do it, or should I save my money for other mods?
Old May 31, 2003 | 07:02 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Differences between C5 & Z06 Stabilizer Packages (y2k02c5)
Zack, I have the Z51 I think the only diffrence between the Z51 and Z06 FE-4 is that the rear bar is a litte larger. What suspension do you have ?
Old May 31, 2003 | 10:51 PM
88sk's Avatar
88sk
Default Re: Differences between C5 & Z06 Stabilizer Packages (Snake Slayer)
NO,the front is larger,Z-51 fr.28.6, rr.23.6---ZO-6 fr. 30, rr.23.6, all in mm.
Old May 31, 2003 | 11:58 PM
YLWFVR75's Avatar
YLWFVR75
Default Re: Differences between C5 & Z06 Stabilizer Packages (88sk)
I've got the Z51 setup as well.
Old Jun 1, 2003 | 02:39 AM
Bill Dearborn's Avatar
Bill Dearborn
The Z06 has a stiffer rear spring and stiffer shocks.
Bill
Old Jun 1, 2003 | 03:18 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
:iagree:
Z51- Z06 differences: Front sway is bigger on Z06, rear spring is bigger on Z06. Dunno about shocks.
Is it worth it? From Z51-I doubt it.
From FE1? ABSOLUTELY! I just finished the sway bar change and the springs are on the way. Even just changing the sways made a HUGE difference.
Old Jun 1, 2003 | 03:56 AM
88sk's Avatar
88sk
Default Re: Differences between C5 & Z06 Stabilizer Packages (Umrswimr)
was thinkin about the same ,got stock bars ,did the ride get harsher when u changed , what diff. did u notice??
Old Jun 1, 2003 | 06:57 AM
silversport's Avatar
silversport
I had the standard set up...switched to Z06 bars ('03) from Ken Fichtner Chevrolet...it does not change ride quality at all...no harshness, none!
It does turn in better and seems more buttoned up...I think it's worth it from standard to Z06... :thumbs: :party: :grouphug: :hurray: :chevy :seeya
Old Jun 1, 2003 | 09:46 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Differences between C5 & Z06 Stabilizer Packages (silversport)
I think going from Z51 to Z06 will be a minimal improvement, unless you are a very experienced racer or autocrosser.
I am neither of the above, but when I went from FE1 to Z51 bars and Bilstein Sport shocks, the difference was amazing. Just went from runflats on C5 rims to GY Supercars on Z06 size rims...I think I've reached nirvana (until I get a flat!)
Old Jun 1, 2003 | 01:26 PM
Snake Slayer
Cruise-In V Veteran
Thanks sorry about that. From Z51 the only way I would go would be GM T-1 bars. They are not for everyone, but a few guys run them on the street.
Old Jun 2, 2003 | 02:27 AM
88sk's Avatar
88sk
do you have to get an alignment with just changing the sway bars?
Old Jun 2, 2003 | 07:57 AM
silversport
nope
Old Jun 2, 2003 | 09:51 AM
vic kovner's Avatar
vic kovner
Default Re: Differences between C5 & Z06 Stabilizer Packages (C5 StockSwap)
Good to see another Convertible that has become a Z06 and more.
Old Jun 2, 2003 | 11:03 AM
SMOKNC6Z06's Avatar
0SMOKNC6Z06
Former Vendor
Default Re: Differences between C5 & Z06 Stabilizer Packages (vic kovner)
On my 98 Z51 car. I went to the Z06 front bar, and already had the aluminum links. I noticed a very very subtle difference, alittle firmer. I don't think it was worth the change, but then again, every little bit helps. A bigger difference was going to the Biltstein Sport shocks over the Z51 shocks.
Old Jun 2, 2003 | 11:33 PM
AFVETTE's Avatar
AFVETTE
I too spent the $270 and bought my Z06 bars from Ken Fichtner. Vastly improved cornering over the base suspension. With the new Michelins I think I might be able to take the Bilstein Sports.
No alignment is required/needed replacing the bars or shocks.
Tom
To Differences between C5 & Z06 Stabilizer Packages
