Low Washer Fluid being displayed ... tank is full..
Old 06-02-2003, 11:13 PM
WannaBe TT!
WannaBe TT!'s Avatar
Default Low Washer Fluid being displayed ... tank is full..
The sensor in the windshield wiper fluid reservoir fell out and the windshield washer fluid came out of the tank. So I plugged the sensor back into the tank and went to drive to the auto parts store to get washer fluid and it throws up "low washer fluid" on the little on-dash display. So i buy washer fluid and fill the tank up, and on the drive home it throws up "low washer fluid" again. It has been doing this for a week now and the windshield washer fluid reservoir is completely filled. Is it possible i put the sensor back in the tank incorrectly? I'm not really sure why i'm having this problem. I appreciate any help. Thanks.
Old 06-03-2003, 01:30 AM
mapman
mapman's Avatar
Default Re: Low Washer Fluid being displayed ... tank is full.. (WannaBe TT!)
Did you clear the Diagnostic Trouble Code (DTC)? The links below may help in clearing codes using the Instrument Panel Cluster (IPC) The IPC is supposed to clear a DTC automatically if the malfunction has not occurred within 50 ignition cycles.
http://www.stengel.net/diccodes.htm http://www.c5forum.com/ayc/2000dtc.php http://www.c5-corvette.com/IPC_Display.htm
Old 06-03-2003, 12:33 PM
The Batman
The Batman's Avatar
Default Re: Low Washer Fluid being displayed ... tank is full.. (mapman)
I really don't know any better, but a "low washer fluid" warning seems more akin to "low fuel" or "door ajar" or "trunk ajar" warning, that is, something that's not worth saving as a DTC. I mean, if I was designing these warnings, I wouldn't expect the majority of owners to know anything about clearing a DTC for "low washer fluid" - Average Joe C5 owner (doesn't know about corvetteforum, doesn't wave) sees warning, fills up washer fluid resevoir, doesn't see warning anymore. Voila. At least that's the way it should work.
How did the sensor pop out in the first place? Maybe it was damaged when that happened or damaged upon re-installation?
I one had a persistent problem with a car and a "low-coolant" warning. It wasn't fixed until I replaced the low-coolant sensor. It was a common enough problem that I could easily find information about it online. Seems like something with no moving parts shouldn't be too prone to failure, but I guess heat and vibration can be enough to destroy or at least significantly diminish the life-cycle of some liquid sensors.
Old 06-03-2003, 12:59 PM
SeaFive
SeaFive's Avatar
Probably needs a new sensor :yesnod: C5s are notorious for washer fluid tank sensor failures :cheers:
Old 06-03-2003, 01:24 PM
Timmy's C5
Timmy's C5's Avatar
Default Re: Low Washer Fluid being displayed ... tank is full.. (SeaFive)
Wannabee TT doesn't say what year his C5 is. Early C5's were prone to this error. It drove me crazy with my '98. Disconnect the sensor from the tank. Take a paper clip and cut off one of the 180 degrees ends. Sweeze the ends together, and insert it into the sensor so one end goes into each portion of the socket. This will complete the circuit and fool the sensor into thinking the tank is always full.
Old 06-03-2003, 03:32 PM
CAPN17
CAPN17's Avatar
Why not clear the codes, get a new sensor, put it in and be done with the problem.
Old 06-03-2003, 03:55 PM
rbocky2k
rbocky2k's Avatar
Default Re: Low Washer Fluid being displayed ... tank is full.. (CAPN17)
Just unplug the wires at the sensor, it won't set a code.
Old 06-04-2003, 12:19 AM
CCrane65
CCrane65's Avatar
My 00 coupe did the same thing. Had the sensor replaced and no more code.
Old 06-04-2003, 08:23 AM
geekracer
geekracer's Avatar
:iagree:
Old 06-04-2003, 09:10 AM
Miaugi
Miaugi's Avatar
Default Re: Low Washer Fluid being displayed ... tank is full.. (MMarquez)
Before getting a new sensor here is a tip for you. I flushed out my washer tank and took the sensor out while doing the job. It is a simple float arm with a magnet imbedded into it, the magnet activates a switch similar to alarm sensors on doors in homes and businesses. The thing that I noticed was the float pivot point was stiff and did not move freely. I took out the pin and shaved off a little material on the float arm (a quick pass on a file or sandpaper will do it). Put it back together and the arm was completely free moving. I think this stiff pivot might get stuck and therefore cause false readings. An easy DIY'er job. :thumbs:
PT5150 (07-16-2023)
Old 06-04-2003, 10:16 AM
SAXN8R
SAXN8R's Avatar
I bet you put the sensor in upside down. Turn the sensor around 180 degrees. That should cure your problem.
Old 06-04-2003, 02:53 PM
WannaBe TT!
Default Re: Low Washer Fluid being displayed ... tank is full.. (SAXN8R)
Thank you all for your replies and a special thanks to saxn8r. I had put the sensor in upside down. I looked at the sensor for a directional orientation and couldn't find any. I remember thinking of that earlier and i rotated it around a little, but i guess it wasn't enough (or was in the wrong direction). Anyways, it's working now. Thanks again!
Old 05-12-2012, 08:57 PM
wilkinru
wilkinru's Avatar
Thank you. Solved that stupid thing.
How annoying.
Zip tied it next to the sensor, it can shutup
To Low Washer Fluid being displayed ... tank is full..
Quick Reply: Low Washer Fluid being displayed ... tank is full..
