cruise control cuts out
Old Jun 2, 2003 | 11:26 PM
Charlie from Cherry Hill's Avatar
Default cruise control cuts out
A few weeks ago (mid-May) I was driving my '99 FRC and suddenly the cruise control (set to 60 MPH) was disengaged. The DIC read "Cruise Control Disengaged". I tried to reset the CC, but nothing happened until about 15-20 minutes later when I set it again. It worked for a while, but then disengaged on its own again and I did not hit the brake. When I moved the switch to Resume again, nothing happened. I turned the CC off and then back on and hit Set...nothing happened. The next week it worked fine on a long trip. A week ago it self disengaged again and I could not set the CC until 15-20 minutes passed again. I set the CC in 6th gear each time. Has anyone experienced this? :confused:
[Modified by torch red ryder, 11:27 PM 6/2/2003]
Old Jun 3, 2003 | 12:48 AM
HawkIVette's Avatar
HawkIVette
Default Re: cruise control cuts out (torch red ryder)
Same thing happens on my '99 FRC also, but I have kinda connected it to a bump in the road.
I will notice it cuts out right after hitting a bump. I think the sensor on either the brake pedal or the clutch pedal is set to sensitive and needs to be adjusted. It gets jarred by the bump and won't reset because it thinks I still have my foot on the pedal. Just my opinion.
Maybe someone else has a better explaination.
Old Jun 3, 2003 | 09:56 AM
BayouVette's Avatar
BayouVette
Default Re: cruise control cuts out (Rich's75)
if you do a search on it you should found a thread that tells you how to fix this problem. It seems to be a somewhat common occurrence...
Old Jun 3, 2003 | 10:17 AM
keith5's Avatar
keith5
Active Streak: 90 Days
Same thing here. Turned out to be aa electrical connector on the undercarriage was loose. Squeezed it back in place and has been perfect ever since (2 yrs) :thumbs:
Old Jun 3, 2003 | 06:11 PM
Tom Steele's Avatar
Tom Steele
Another place to check is your brake pedal connection to the CC. I had this problem with my 2000 and it turned out to be that the brake pedal was sticking ever-so-slightly and dis-engaging the CC.
Old Jun 3, 2003 | 06:21 PM
JCR's Avatar
JCR
There is an updated PCM program that prevents unwanted cruise drop out. The recalibration is only available through GM dealerships
Old Jun 3, 2003 | 06:32 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Another problem area that can cause this is the turn signal stalk/cruise control unit itself. It's standard issue GM (something quite clear during the years when I was driving both my 99 and my old 93 Suburban). Mine would disengage when I signalled a right hand lane change (not setting the signal lever in the indent, just holding it for a temporary signal). Not every time, of course. Always hooked right back up again when I hit "resume". Go figure. :crazy:
Old Jun 4, 2003 | 10:36 AM
iwannac5's Avatar
iwannac5
Default Re: cruise control cuts out (pastorbrad)
your not alone, my 99 frc does the exact same thing when i hit a large bump and when i signal a lane change. funny to read your post because i was about to do a search to see what i could find, and post this exact question if i couldn't find anything. you beat me to it. :)
Old Jun 4, 2003 | 02:51 PM
THRAP 42's Avatar
THRAP 42
Default Re: cruise control cuts out (iwannac5)
Had this same thing happen on my sister-in-laws car. When she signaled to change lanes the cruise disengaged. Come to find out it was a burnt out tail lamp. Changed the bulb and it works fine now.
later,
Old Jun 4, 2003 | 11:19 PM
Thank you all for your response to my question. I will take a print out of this thread to my Chevrolet Dealer next week. Hopefully it will help to repair the problem. :thumbs:
Old Jun 5, 2003 | 06:30 PM
Pooter's Avatar
Pooter
I had the same problem when I bought my '99 six months ago. It would cut out when I hit a bump. To fix it I had to take off the under side of the dash, and get to two small white actuators that contact the brake pedel. This is a back breaking maneuver to reach! The actuators have a small collar that hold them in place. Push the actuator back into the collar from both sides. Both of mine were off only 1/16", but this was enough to make it stop working. I have not had it do it even once since then. Sorry but brainfreeze stopped me from thinking of another word for "actuator". :D
Old Jun 5, 2003 | 07:25 PM
jmX's Avatar
jmX
Good to hear I'm not the only one with this issue.
Old Jun 12, 2003 | 06:46 PM
I took the car to the Chevy dealer today. Switch to clutch was partially disconnected, so CC worked intermittently. Technician re-connected it and reprogrammed the engine control module. Lucky I have the extended warranty. It seems fine now. Thanks again for all of your input.
To cruise control cuts out
