DTC B2263 - Please offer some help
Old Jun 3, 2003 | 11:23 AM
Kenny94945's Avatar
Kenny94945
Default DTC B2263 - Please offer some help
Passenger Horizontal Mirror Sensor.
It is intermittant...8 out of 10.
Affected with memory system both key pad no. 1 & 2 and with the easy entereance/ exitfunction.
Can some one offer a specif wire that they have seen chaffed or other area to investigate.
If I am not mistaken the manual calls for replacing the mirrror asy. What involved with that replacement?
Old Jun 3, 2003 | 11:48 AM
mapman's Avatar
mapman
Default Re: DTC B2263 - Please offer some help (Kenny94945)
Most intermittent conditions are caused by faulty electrical connections, so your mirror assembly may be ok.
Check for wires broken within the insullation, poor connection between the male and female terminal at a connector.
Poor terminal to wire connection - bad crimp, corrosion, etc
Wire insulation that is rubbed through causing a short as the bare area touches other wiring or parts of vehicle.
The electrical section of the service manual is pretty detailed, you may want to get access to a copy if you are going to do anything involved. :)
