Alignment settings after shock and spring replacement
Old Jun 3, 2003 | 01:00 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Default Alignment settings after shock and spring replacement
On my 2000 coupe with base suspension, I'm replacing my shocks with Bolstein heavy duty shocks and I'm replacing the springs with Z06 springs. I've already got the Z06 sway bars. Should I go with the stock alignment or the Z06 spec alignment??? :confused: :confused:
Old Jun 3, 2003 | 01:10 PM
Mitch Alsup's Avatar
Mitch Alsup
Default Re: Alignment settings after shock and spring replacement (jw38)
If you want the car to drive like a Z06 then use the Z06 alignments (e.g. agressive, with grip weighting more important than tire life). Otherwise, use the standard settings.
