Looking for comments on my exhaust plans
Old Jun 3, 2003 | 02:07 PM
JakeL's Avatar
JakeL
Default Looking for comments on my exhaust plans
All - looking for a bit of advice.
I'd like to wake up the sound of my C5 a bit. After doing a bunch of research, I've decided to go with (from heads to mufflers:)
- LG Headers with cats
- LG X-Pipe
- Z06 Ti Exhaust
For the moment, the LG headers are a bit rich for my blood. I am pretty set that that's what I'd like in my car however. I should be able to swing the Ti before too long.
My main question is this: Should I wait to do the X-pipe when I do the Long-tube headers, or can I do it along with the Z06 exhaust? Are there any fitment issues to worry about with the LG X-pipe to the stock headers/cats, and/or to the Z06 exhaust?
Further, any suggestions or obvious things I may have overlooked on that choice of exhaust setups?
Thanks for any help,
-Jake
Old Jun 3, 2003 | 03:29 PM
CAPN17's Avatar
CAPN17
Default Re: Looking for comments on my exhaust plans (JakeL)
I hope you are figuring on the random high flow cats as part of that set up. It would be a shame to do all that work and then have to go back to pull those stock cats out.
Old Jun 3, 2003 | 03:52 PM
Guest
Guest
Posts: n/a
The LG long tubes cannot re-use the stock cats- the long tubes put the collectors about where the main cats used to be. But they do mate up with the rear section (the Y part) of the exhaust. They can be had with either a nice x-pie, cats, or both if I remember right. I would install(or have them installed) the headers and x-pipe or cat combo first. You can always bolt on the Z06 cat back or something else later.
Old Jun 3, 2003 | 04:40 PM
JakeL's Avatar
JakeL
Default Re: Looking for comments on my exhaust plans (ASP Z)
To clarify:
no, I wasn't planning on using stock cats, I was going to use LG's Random Tech cats that come with their kit, and the off-road pipes if I ever saw fit for that.
ASP Z:
you are saying that the longtubes terminate in the same spot as the stock manifolds (i.e. where the stock H begins), making everything a swap-in/swap-out?
The idea of doing the LT's first hadn't ocurred to me - that's not a bad idea.
Thanks!
-J
To Looking for comments on my exhaust plans
