dash light bulb
Old Jun 4, 2003 | 06:04 PM
TANKER's Avatar
TANKER
Default dash light bulb
my 01 coup has aburned out bulb in the off button in the ac heater pane4l i tried to pop the button but stopped when it didnt come out how does one change a bulb in there
Old Jun 4, 2003 | 10:08 PM
BlackZ06's Avatar
BlackZ06
Default Re: dash light bulb (TANKER)
This is a test, right ???
The Automatic HVAC control does not have a light in the OFF button. The buttons that do have lamps look like they're LEDs, so they should never "burn out".
Old Jun 5, 2003 | 10:40 AM
TANKER's Avatar
TANKER
Default Re: dash light bulb (BlackZ06)
no test the push buttons ie off ac etc they each light up one is out do the buttons come off to change bulbs
Old Jun 5, 2003 | 01:41 PM
BlackZ06's Avatar
BlackZ06
In your original post you said the OFF button is burned out. The OFF button DOES NOT have a light in it. :banghead:
If another button is not lighting up (be specific, which one is not working??) then no, they do not come out, the panel is serviced as a unit. However, it may not be a burned out light (they can't burn out - they're LEDs) but rather a problem somewhere in the HVAC system. Check the car for DTCs, especially something like a P1546, which would indicate that the A/C compressor clutch is not being engaged, in which case the A/C light will not come on.
[Modified by BlackZ06, 10:43 AM 6/5/2003]
Old Jun 7, 2003 | 09:27 AM
TANKER's Avatar
TANKER
thank you the whole unit needs to be changed thank god for x warentee
To dash light bulb
