Something is wrong...
Old Jun 5, 2003 | 06:47 PM
MeatheadsC5's Avatar
MeatheadsC5
Default Something is wrong...
For some reason, when I floor the gas, the engine revs up normally then suddently bogs down about 300-1000 rpm. It does it in every gear, and the effect is exaggerated the lower the rpm I start in.
Lets say I'm driving in 4th gear at about 60 mph at 2500, if I floor it, the engine surges up then bogs back down to about 2000 as my speed increases, and there is a significant loose of top end power.
Also sometimes if I hit it hard in first in will bog right of the start almost like the fuel isn't getting in there. Its mostly on the top end though.
Traction control off/on makes no difference.
AC on/off has no effect.
I don't race or even get my car over 5k much at all, I just noticed it because I decided to do a little tire smoking on the highway on the way home and test my speed shifting.
What could this be.
Old Jun 5, 2003 | 07:14 PM
THENAKEDi's Avatar
THENAKEDi
Default Re: Something is wrong... (99Mongoose400SS)
Are you throwing any codes on the DIC?
Old Jun 5, 2003 | 07:18 PM
MeatheadsC5
Default Re: Something is wrong... (THENAKEDi)
Have not hooked it up to autotap. WIll do this weekend.
Temp, pressure etc all fine.
Old Jun 5, 2003 | 07:19 PM
jmX's Avatar
jmX
If you have a 6 speed, and you can punch the gas and the engine revs up then the rev's come back down, your clutch is slipping.
Old Jun 5, 2003 | 07:30 PM
MeatheadsC5
Default Re: Something is wrong... (jmX)
Actually that was a first thought, though I wanted other opinions before I posted it. That's what I was afraid of. Well 38k I guess its time. Z06 here I come - great how much are those now.
Old Jun 5, 2003 | 07:43 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Very possible! :iagree:
Old Jun 6, 2003 | 12:57 AM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
:iagree:
Old Jun 6, 2003 | 01:17 AM
CAPN17's Avatar
CAPN17
:iagree: :cry :cry :iagree:
To Something is wrong...
