Two headlight problems, need tech advice
My drivers side headlight continues to run for about 5 seconds after it goes down, and it makes a clicking noise.
Problem #2
The headlights go up when I only turn on the parking lights.
Also, I don't know if this is related, but the fog lights are both not working. I haven't checked the bulbs, but they both went at the same time.
Any ideas?
Thanks,
Shawn
I drive sometime with just the fogs on.
Took me 40 minutes ... to replace (four 10mm bolts and three water pak connectors to unplug... I took the motor apart after the fix.. to see what broke.. I have a 99 and the drive gear is steel.... the ring gear is nylon... and it was missing about three teeth.. also the grease used to lub these gears was hard as a rock.. possibly bad grease, wrong grease, or just worn out..
2 things to consider, check http://www.artscorvetteparts.com/ for used/new parts of all kinds. Search on your year.
Seems I remember seeing the whole actuator assembly there. If not just note the site for future reference.
Also invest in a set of factory service manuals, if the fix one problem for you, you'll get your return on the $110 investment.
Not to mention it's good reading.
I hate to post hearsay, but maybe it's the truth. If so maybe it'll save you money.
I saw a post stating the headlamps will not close or operate normally if there is a bulb failure. You said the fog lamps don't work. Possible a fuse or bad bulbs in the fog lamps?
Also check for codes, you never know. Maybe that will point you.
Let us know.
[Modified by Bugster57, 9:33 AM 6/23/2003]
