Should I drive with a busted plug???
After reading on here about the stock plugs losing their pucks, I decided to take mine out to inspect them. Man, they're in TIGHT!! Started with the easiest-looking plug (passenger-side front) and managed to crack the insulator using a wobble socket! :eek: It's only slightly cracked... from the top of the insulator down about 0.5", but it's enough to make the car miss pretty badly and throw a P0300 :(
My question is this... do I risk any harm driving the car as it is? My daily commute to work is an 80-mile round-trip, so I'm thinking I should NOT drive the car. Trouble is, I'm in the UK and getting hold of a replacement plug is gonna be a PITA (like I may have to wait a week while one is ordered).
Thanks,
Ian.
:cheers:
It would also be a little difficult driving the car for 80 miles with a bad misfire on one or two cylinders. And you dont want to make anymore problems for yourself over a couple dollar spark plug. So if you have another way of getting around until you get a plug i would do so.
Know that this is a PITA (awaiting delivery of new plugs), but is less of one than having additional issues develop by driving with a know issue and causing more issues.
Are you sure though that you'd have to special order the plug? I hope it's not too obvious but have you tried going to Halfords and looking in the spark plug cross reference there?
Also, if it helps, both Denso and NGK have offices in the UK. Maybe a call there will help you locate an outlet? Denso Sales UK: 01707-282400, NGK Spark Plugs (UK) Ltd: 01442 281000
Looked-up the specs of the OEM plug (14mm thread, 16mm hex, 18mm reach, taper seat) and found I had a brand new Autolite plug in the garage that had the same thread and hex sizes, but with a compression gasket and +1mm reach. To take care of the extra reach, I just put another compression washer on the plug. Just took the car out and it seems fine (although I'll take it a little easy just in case I get clearance issues at high revs). The 'new' plug is also 1 heat-range cooler, but that shouldn't be a problem.
Gets me out of a fix until I can get my hands on a set of new plugs, anyhow :)
By the way, my old plug was fine... good colour, puck still in place and gap exactly right (60-thou) at 28k miles.
Here's a pic of the cracked plug (ouch):
Cheers,
Ian.
:cheers:
