My rear end is dripping
Old Jun 8, 2003 | 12:54 PM
ROD BROWN's Avatar
ROD BROWN
Default My rear end is dripping
Walked out to the garage and I noticed a little pool of oil under my rear end.Any body have a suggestion as a fix it your self solution?I believe this is a common problem with Vettes. :chevy :chevy :flag :chevy :chevy
Old Jun 8, 2003 | 01:58 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Default Re: My rear end is dripping (ROD BROWN)
There is a pretty common problem with the seal on the drivers side halfshaft where it enters the differential. These start leaking on a fairly regular basis. Do a search there have been plenty of previous threads about this problem. Dealer will fix it under warranty for you.
Old Jun 8, 2003 | 02:07 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: My rear end is dripping (CHJ In Virginia)
You could always try Depends :lol: :lol: :jester
:cheers:
Jeff
Old Jun 8, 2003 | 08:24 PM
NealB's Avatar
NealB
my 03 Z06 is now puking diff lube on the garage floor at 3300 miles
not coming from driver side seal as mentioned above
2001 Coupe had the same issues, and the answer was they are all overfilled and they all do that and don't worry
can't wait to hear which answer on the 03
Old Jun 8, 2003 | 08:41 PM
Guest
Guest
Posts: n/a
"My rear end is dripping"
... there are some bad jokes there, just waiting to happen...
:lolg: :lolg: :lolg: :jester
Old Jun 8, 2003 | 09:03 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: My rear end is dripping (MMI)
What color is Differential oil ??
:cheers:
Jeff
Old Jun 8, 2003 | 10:04 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
... YOU SOULD SEE A DOCTOR ! :eek: :lol:
Old Jun 8, 2003 | 10:14 PM
blackjack's Avatar
blackjack
Default Re: My rear end is dripping (johnnyvettes)
Check the fluid level. It migh be over filled and coming out of the breather. Mine was...
Blackjack :auto:
Old Jun 8, 2003 | 11:13 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: My rear end is dripping (blackjack)
I had the same problem this morning and figured it's the seal. If it was overfilled wouldn't it have leaked from the beginning. Why would it leak after 10,000 miles and not before. BUT I will check for a breather. Is it easy to find? I guess I am asking where is it. TIA
Old Jun 8, 2003 | 11:25 PM
NealB's Avatar
NealB
Default Re: My rear end is dripping (edpainter)
my 01 Coupe never leaked until 11,000
got the "overfilled" story from the dealer
they drained some out, and it still dripped till I sold it at 15,000
Old Jun 8, 2003 | 11:44 PM
blackjack's Avatar
blackjack
Default Re: My rear end is dripping (NealB)
Breather is on the top left side of the diff...
Old Jun 8, 2003 | 11:52 PM
gojo's Avatar
gojo
Another thing to check is the drain/fill plug on the tranny. They sometimes need a little sealant and the oil that's dripping is blown back to the rear-end and is misleading.
Old Jun 9, 2003 | 01:26 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: My rear end is dripping (jfpilla)
Can you get it done on warranty? Mine was fixed by the dealer twice under warranty.
Old Jun 9, 2003 | 01:17 PM
mozart's Avatar
mozart
Default Re: My rear end is dripping (FunDriver)
Just had my half shaft seals and diff cover gasket replaced at 12k for minor leak. Was done under warantee at no cost to me. The dealer forgot to put the posi additive in the differencial and took it back for the additive to be added to the diff. Have had no leaks since but only put on about 600 miles since work was done. Time will tell.
Old Jun 9, 2003 | 02:41 PM
STRONGBOW's Avatar
STRONGBOW
I also think you need to see your Doc :lolg:
Old Jun 9, 2003 | 03:02 PM
jimman's Avatar
jimman
Default Re: My rear end is dripping (mozart)
mines currently in getting transmission fixed and the seals are leaking near the half shafts. Tech says common problem and will replace. The interesting thing is that in CA they aren't allowed to put in the additive for slip because it's hazadous material. They just happend to find a bottle and will add.
Old Jun 9, 2003 | 03:48 PM
Chopper Larry's Avatar
Chopper Larry
10k ON THE '02 and noticed the same thing today. Just a few small drops;
but it was rather dark. I at first thought maybe one of the Harley's had been parked there, but I remember the Vette was in it's stall the whole time.
To My rear end is dripping
Old Jun 9, 2003 | 06:08 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Like put a cork in it!!!!!!! :lol: :lol: :lol: :lol: :lol:
Seriously, drop the tranny and gear and replace the seals.
Old Jun 9, 2003 | 06:42 PM
robsvette's Avatar
robsvette
Default Re: My rear end is dripping (wallstAL)
stop hanging with jon pine and ur rear end will stop leaking :p: :smash: :eek:
Old Jun 9, 2003 | 08:12 PM
ROD BROWN's Avatar
ROD BROWN
Well,I crawled under the car checking for my rear end leak and I discovered the transmission bolts were loose.I wonder how many owners wre told they needed seals and gaskets when all that was wrong was tightening up the bolts.No more leak.My rear end is DRY. :chevy :chevy :flag :flag :chevy :chevy
