"check engine light"
Old Jun 8, 2003 | 06:21 PM
Tombone's Avatar
Tombone
Default "check engine light"
What is the common contributing factor for this light to remain on steady?
What is the correction?
Thanks, Tom. :confused:
Old Jun 8, 2003 | 07:25 PM
mapman's Avatar
mapman
Default Re: "check engine light" (Tombone)
What codes are set?
Old Jun 8, 2003 | 09:18 PM
Tombone's Avatar
Tombone
Default Re: "check engine light" (mapman)
How do I determine the code?
Old Jun 8, 2003 | 09:21 PM
Joe97's Avatar
Joe97
http://www.stengel.net/diccodes.htm this will give you all the info you need :thumbs:
Old Jun 8, 2003 | 10:28 PM
Tombone's Avatar
Tombone
Default Re: "check engine light" (Joe97)
10-PCM one code
"Range low"
What does that mean???
Old Jun 9, 2003 | 12:19 AM
mapman's Avatar
mapman
Was there a 4 digit code when you ran the diagnostic?
Old Jun 9, 2003 | 09:46 AM
Tombone's Avatar
Tombone
No.
Old Jun 9, 2003 | 05:58 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
No.
Not true , you may not know how to do it.
Push and hold options button while pressing the fuel button four times. Your codes will start to scroll.
To "check engine light"
