Header install Oooops
Old Jun 9, 2003 | 10:43 AM
SideStep's Avatar
SideStep
Default Header install Oooops
:bb
When installing my LT system this weekend I forgot that the rear O2 sensor wires are suppose to cross :rolleyes:
I plan on fixing this as soon as I can, but in the mean time what problems (if any) could this cause?????? :confused:
:cheers:
Old Jun 9, 2003 | 10:51 AM
Chris@SD's Avatar
Chris@SD
Default Re: Header install Oooops (SideStep)
Absolutely none that I can think of. If you throw a cat code and it says right side, it is going to actually be the left side. Other than that, nothing.
Good Luck,
PS Watch for burnt wires...
Old Jun 9, 2003 | 10:55 AM
SideStep's Avatar
SideStep
Default Re: Header install Oooops (Chris@SpeedDemon)
Good Luck,
Cool, thanks!!!
What do the rear O2s do anyway????
:cheers:
Old Jun 9, 2003 | 11:04 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
They just give your PCM the Thumb's Up that the catalytic converters are doing their job. They monitor the oxygen conten of the exhaust gasses after the cats and there should be a difference if the cats are present and functioning.
Old Jun 9, 2003 | 12:11 PM
SideStep's Avatar
SideStep
Default Re: Header install Oooops (MattG)
Thanks, also!!!
This gives me a little time to climb under again and do the swap!!!!
I LOVE THE FORUM, free information in less than an hour!!! :thumbs: :thumbs: :thumbs:
:cheers:
Old Jun 9, 2003 | 07:35 PM
los7883's Avatar
los7883
Your front O2 are the more important ones...they report exhaust gas oxygen back to the PCM. The rear O2's also check the exhaust after the cats to make sure they are doing their job...the fronts put out a certain voltage in proportion to the amount of oxygen in the exhaust...and so do the rears...if the PCM notices there is not that much of a difference in the two voltages, then it thinks that they cats aren't doing their job and may kick out a code.
Old Jun 9, 2003 | 08:38 PM
SideStep's Avatar
SideStep
Default Re: Header install Oooops (los7883)
Thanks for the info!!! :thumbs:
I went ahead and pulled the X-Pipe and the cat pipes and swapped the wires to their correct postion...
Thanks to all for the help :cheers:
To Header install Oooops
